Author Topic: Help with potential purchase  (Read 2095 times)
Offline Rigs
« on: January 20, 2020, 11:29:04 AM »
Hi
Hopefully this is the correct thread.
I've attached a picture of a CB750 I'm viewing on Wednesday and wanted to know if anyone knows the model.
Would the frame be a flat / straight base or would it need fabrication to have a more flat / brat style seat?
Its a project for me and my dad to work on, keeping as original as possible.
Thanks alot
Offline Tews19
  • I am no
Re: Help with potential purchase
« Reply #1 on: January 20, 2020, 11:30:20 AM »
That is not a SOHC. 80s model I think
1970 Honda CB750 survivor.
Offline low-side
« Reply #2 on: January 20, 2020, 11:35:11 AM »
My recollection is that the frame more or less follows the lines of the seat.
Offline jakec
« Reply #3 on: January 20, 2020, 12:59:25 PM »
if you want a cafe racer platform that's fine because at least you won't be chopping up a bike that's worth something :P
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline jakec
« Reply #4 on: January 20, 2020, 01:03:36 PM »
jokes aside I had the same model (81 cb750c) as my first bike. Here's a photo with the seat off.
here it is a few months later with a seat
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
« Reply #5 on: January 20, 2020, 03:46:45 PM »
GET THE KAWASAKI TRIPLE THAT'S HIDING BEHIND IT INSTEAD (in shouty voice) !!  ;)   :D
« Last Edit: January 20, 2020, 03:49:12 PM by ekpent »
« Reply #6 on: January 21, 2020, 06:31:34 AM »
PLUS 1!  Good eye Eric....
« Reply #7 on: January 21, 2020, 06:53:57 AM »
  What's your guess Steve,I say maybe a 250cc ??
Offline Rigs
« Reply #9 on: January 22, 2020, 03:20:17 AM »
Thanks for the picture, that's what I wondering.
Did you keep it stock or did you change the back end at all ?
Seemed to look a little flatter.
And yes I didn't want to cut anything up that was considered a classic year or turning point for engine design etc. Still wanted something with a little character.
I have an old honda shadow myself so this is new ground for me, hence jumping on the forums :)
Offline jakec
« Reply #10 on: January 22, 2020, 09:29:04 AM »
compare the difference from mine to the pic here from the parts fiche. looks like you have to remove the seat support. and a crossbar was added  in its place on my bike.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline Bankerdanny
  • Endeavor to persevere
« Reply #11 on: January 22, 2020, 10:12:16 AM »
Generally speaking fitting a brat style seat requires modifying the frame somewhat, usually in the form of cutting off the bridge looking brace you see in the photo that Jake posted.
Offline Rigs
« Reply #12 on: January 27, 2020, 05:16:49 AM »
I actually had a change of plan as I found a 1974 SOHC CB550.
So I am considering either a restoration or the brat project, depending on what the resale value would be like.
I found £1978 for it so not too bad.
Offline Bankerdanny
« Reply #13 on: January 30, 2020, 10:48:56 AM »
A bit more than I think that bike would be worth in the US, but still looks like a nice complete bike. In my part of the US that is probably a $1,500 bike, so ~£1,200 or so.
Restoring to original would be expensive and you wouldn't get your money back. However, a brat conversion would be expensive too, plus more work, and you still wouldn't get your mone back.
I would do the minimum to get it on the road and MOT'd then ride it for a while to get a feel for it. But either way, I would caution you not to expect to get your money back. 550's just aren't as collectible as 750's and 400's.
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #14 on: January 31, 2020, 06:08:22 AM »
       Well, to each his own, I say. Some don't seem to have any feeling for the DOHC750s and I can fully understand the attraction for the SOHC version, as they Are A Great model. Myself, I couldn't seem to swing a deal on a SOHC750, but did come up with an '80 750 DOHC & started out, to fix it up, with the Sidecar shown in the photo (I worked with folks with Special Needs & was building this one, to give rides, to 2 young boys, I worked with. I retired from that, several years ago though & it's gone. This is the only photo, I could easily come up with. I had NO issues with this 750 & was a Good runner. Just saying'  ;)
Member # 1969
« Reply #15 on: January 31, 2020, 03:38:28 PM »
Yep, that 550 isn't all that collectable, but will be a whole lot less desirable to a wider audience if you chop it up. I'm sure you're not doing it for the money though, so if you don't care about what you can sell it for when you've turned it into whatever your vision of a cool bike is, then go for it. Keep everything you take off it though, (including the tabs and frame sections you lop off) that way someone who wants to take it back to original will have a chance. ;D
Offline Rigs
« Reply #16 on: February 01, 2020, 01:40:40 PM »
Well this is what I'm heading for, not chopping about too much.
But I would say in the UK 550s are hard to find and I've seen even really rough ones selling around 5k.
The guy who sold it is a classic bike shop and had alot of good advice. It's a US import.
« Reply #17 on: February 02, 2020, 11:58:21 AM »
Yep, that looks ok, just don't put those stupid tyres on it, you guys get about 3 days per year with no rain, and those things are no good in the wet, so unless you intend to trailer it everywhere, put some real motorcycle tyres on it.
Just remember to measure twice and cut once, then save whatever you've cut off, I've just spent a lot of time and money replacing whole frame sections after the PO chopped off all the tabs on my Kawasaki Z1000. (Ex drag bike) ;D
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #18 on: February 03, 2020, 07:19:25 AM »
Who's CBX was that in the previous picture?
1973 CB 750 K3
10/72 build Z1 Kawasaki
