Author Topic: New project CB400/4  (Read 2614 times)
Offline allankelly1
New project CB400/4
« on: January 24, 2020, 02:34:14 AM »
Hi all
Always has a soft spot for the CB400/4
And after a chat with the darling wife I am now a proud owner of a red 1977 bike.
The bike itself is reasonably tidy and is running ok and even came with,when I opened up the seat, the original tool kit and a 43 year old owner’s manual
The bike could do wilt  a bit of work here and there and first thoughts were to restore it to an original bike, but to be honest I thought the same when I got my  “project bike” a RD350LC which is now all done
But I would rather have something that is still in keeping with the period but also has a few personal unique touches / changes
Took it out for a quick ride today and the front brake is totally carp and is In dire need of either repair of replacement so first change will be to look at the possibility to replace the complete front disc brake with a more modern  single piston floating calliper twin disc set up off a bike from the mid 80s just to keep the period look
Once this is done and she has had a good check over (and a mot just to tick the box for insurance proposes as it’s not been for a mot since 2012) then I will use her for the summer in its current state while getting other goodies such as a Yoshi cyclone exhaust, ally rims and stainless spoke kit electronic ignition and a few other bits and bobs in preparation for the end of summer where it will be time for a complete strip and rebuild from the ground up just like the RD
In the meantime will keep you all up to date on how goes including the front disc upgrade
Best wishes Al
« Last Edit: January 24, 2020, 02:39:37 AM by allankelly1 »
Offline allankelly1
New project CB400/4
« Reply #1 on: January 24, 2020, 02:36:28 AM »
Hi all
Well decided to take the plunge and convert the CB 400/4 to a twin disc front end
I know it’s not original but really like the symmetry of a twin disc front end and bike was alway going to be slightly different from original anyway
There’s a bit of way to go yet as to get the correct fork length the fork assemblies are 400/4 stanchions / damper assemblies with CB400N lower sliders that will need the lower section of the stanchions modifying to incorporate the later Honda design that has a spilt bush on the bottom of the stanchion that runs in the slider bore rather than the complete stanchion leg
Also hub and discs will need some changes as original disc is a four bolt mounting and the donor discs are five
(And the plain discs will be drilled at some point too)
Lastly due to the extra disc the speedo drive willl need a tweaking to get the drive past the extra disc,
But none of the above are impossible to solve and I have alway enjoyed the challenge of solving problems )Also having access to a full tool room helps ) Plus the bike it will stop much better than the original pivot design
Catch up with you all soon
Best wishes Al
« Last Edit: January 24, 2020, 02:40:55 AM by allankelly1 »
Re: New project CB400/4
« Reply #2 on: January 24, 2020, 09:21:03 AM »
Al,
I'm not sure but it looks like you went with a CB750F or GL1000 front brake set up.
Nice looking 400F and RD350.  What's the other project next to the RD?
Offline allankelly1
New project CB400/4
« Reply #3 on: January 24, 2020, 10:11:21 AM »
Hi
Thanks for the kind comments
No it’s a 1981 CB400N super dream front end
Went this route as the fork stanchion diameters on a CB400N are the same as the CB400/4 at 33mm so a reasonable straight swap other than the speedo drive and mudguard mounting
Also because of the fork change looking to fit a chrome mudguard from the same bike so it matches the fork mounts and this mudguard does not need the two steady bars which suit the new sliders as they do not have the lower steady mounts on the lower forks
I know it will not look totally original but I was alway going to go “my way” and hopefully the final bike will look similar to this
I know the CB400N front wheel is a 19” unit but that means we will only have in theory an extra 12mm gap
As for the other bike you spied it’s another project in progress
The bike is being built round a one off Tigcraft Super Mono race frame and fitted for suspension is a Honda MC21 swingarm with an Olins shock and the front is from a Cagiva Mito. Wheels are KTM and brakes are Brembo. Lastly engine is a Yamaha 350 YPVS unit
Like I said it’s a slow burn project in progress that has its own unique challenges unlike the normal restore / tweak
Here are some more pictures of it
And think when its done it will look pretty awesome
Catch up soon and have a good weekend
Best wishes Al
« Last Edit: January 26, 2020, 12:29:32 AM by allankelly1 »
« Reply #4 on: January 25, 2020, 03:44:18 PM »
JeeeeZ! That super mono project looks spectacular -- great track bike.
« Reply #5 on: January 26, 2020, 02:56:30 PM »
Hey Al....love the RD and the mono project.  I too have an RD, it's a '73 stocker.
Subscribed to follow what you do on the 400, looking good so far...
Offline allankelly1
« Reply #6 on: January 29, 2020, 11:22:49 AM »
Hi all
Just a quick update
Managed to dry fit the twin disc set up on the bike and all looks good so far
As for the fork stanchions as I mentioned they needed a modification so that they match the original CB400N forks so they will work with the CB400N lower sliders, so spent some time in the workshop today modifying the ends to match the original CB400N forks stanchions
Plan now as the stanchions are finished are the get them off to Brooks for rechroming and while they are away sort out the rest of the modifications like modifying the front hub from a 4 bolt disc mount to a five to match the new discs and refurb the rest so when the parts are back from Brooks I am in a position to fully rebuild the complete fork and brake assembly
Think thats all for now
Best wishes Al
Offline allankelly1
New project CB400/4
« Reply #7 on: February 12, 2020, 11:51:40 AM »
Hi all.
Well the saga of fitting twin disc to my project CB400F continues
To be honest its not an easy change and requires lots of slight changes and modifications. And due to the twin disc set up the original speedo drive does not fit as the second disc gets in the way of the cable run
But after a bit of thought problem solved
So decided to fit a drive from a CB400N also (as it’s the same ratio as a original CB400F unit) but it’s not a straight fit due to me wanting to keep the original CB400F front hub
Needed to do a few modification to the drive itself as the original width was 32mm but it needed to machine it down to 28mm to suit the CB400F hub width, so have now modified the drive to this new width that including modification to the housing and drive gear
Also due the the original hub design I lost the original drive dogs so designed and 3D printed at home a new drive dog part in an engineering nylon and then attached the to the original hub with two tapped M3 screws
And then the speedo drive simple mounts on this new driver dog plate
Really please with the final result and now have a fully sorted speedo drive
 Next step is to finish the dry build of the front end and then once happy get the sliders powercoated and finish the rebuild of the front end
Think that is all for now
Best wishes Al
« Last Edit: February 12, 2020, 01:02:51 PM by allankelly1 »
Offline allankelly1
New project CB400/4
« Reply #8 on: March 21, 2020, 10:15:32 AM »
Well bike slowly getting there
Hybrid forks all now rebuilt and fitted
Also now fully restored the clocks
Now just started to rebuild both front calipers and then once they are done all that will be needed is to rebuild the wheels with there nice and new alloy rims, stainless spokes and new tyres
Thens just a bit of tidying to get the bike mot’ed ready for the  summer while I plan the next phase of changes
Offline rickmoore24
  • Be led by your dreams, not pushed by your problems.
  • I <3 SOHC4's
    • Rosenbard Films
« Reply #9 on: March 21, 2020, 11:04:40 AM »
Great work thus far and those other bikes are sweet, love the solution for the speedo drive. I'm currently working on a 400F as well but my starting point isn't anywhere near as nice as your project.  :)  Rick.
1972 CB750 K2 (Daily Runner)
1972 CB750 K2 (Sold)
1973 CB750 K3 (Hardtail 836cc)
1998 CBR F3 - R.I.P., went down on the 101 in Calabasas, Ca.
1995 EG6
Offline allankelly1
« Reply #10 on: March 29, 2020, 07:30:31 AM »
Hi
Progress bit slow at the moment as have been doing other stuff but got the rechromed stanchions back from Brooks this week so can start to finish of the front end
But while waiting for the stanchions I have been doing some other small jobs like made up a splitter for the twin disc/  calipers set up the other day that uses the original brake light switch so I can keep the original brake master look and planning to model up a cover to fit over this assembly
The original front headlight was not great, but as I wanted a different  look from a original bike going to move away from original and playing around with possibly fitting something like this with more better looking indicators
Also on the go I am  currently rebuilding the original clocks
And lastly got the new alloy rims the other day from CWS
So like I said progress is a bit slow at the moment but lots of jobs progressing well
And think it won’t be long before I am home full time  so will have plenty to do when in self isolation in the garage
That’s about all for now
But to everyone keep safe and wish you all good health to you your family and friends
Best wishes always Al
Offline allankelly1
New project CB400/4
« Reply #11 on: March 29, 2020, 07:39:54 AM »
Hi all
Bit more self isolating this week
Front end now complete with rebuilt calipers and venhill hose
Front end is starting to look pretty tidy now
Next job is now to learn how to build a spoked wheel  so I can replace the original rusty rims and spokes with nice and new alloy rims and stainless spokes plus replace those old tyres with new rubber too
But I guess I will have plenty of time on my hands to watch tutorials and learn
Stay safe all in these times.
« Last Edit: March 29, 2020, 07:43:20 AM by allankelly1 »
Offline allankelly1
« Reply #12 on: April 02, 2020, 03:08:14 AM »
Hi just a quick update
Started to lace up the front wheel
Took loads of photos of the old wheel as a guide but still struggle at first but after some head scratching and some input from
the darling wife  and the dog it looks like it has all come together
Just need now to true it up and get the off set right
Offline allankelly1
« Reply #13 on: April 02, 2020, 03:10:01 AM »
Hi all
After a bit of time pretty pleased with the front wheel
It’s actually better than the Rd
Catch up soon and stay safe all.
Best wishes Al and the dog
Offline allankelly1
« Reply #14 on: April 02, 2020, 03:11:20 AM »
Hi
Got the rebuilt front wheel back in the front forks to check rim is central about forks
All looks good and well pleased with the result
Just needs a new tyre and mudguard but will sort that out once the back wheel is finished too
Catch up soon
Best wishes and stay safe Al
« Reply #15 on: April 02, 2020, 07:41:37 AM »
You and the Dog are doing some fine work over there!
Are you going with stock mudguard?
What brand tyre??
Offline allankelly1
New project CB400/4
« Reply #16 on: April 02, 2020, 07:52:16 AM »
Hi Stev-o
Thinking of fitting the standard CB400N mudguard as the original won’t fit the lower sliders as they are also CB400N
Got a cheap on of eBay to check what it looked like before I commit to getting a new replica from Dave Silvers
It looks ok even though it’s for a 19” wheel, it does have all the mounting holes in the correct place like the brake line guides and the speedo cable guide, as the speedo drive is now on the left hand side to the original position
As for tyre thinking if fitting Avon Roadriders
Catch up again soon
Best wishes Al
« Last Edit: April 02, 2020, 11:12:22 AM by allankelly1 »
Offline allankelly1
« Reply #17 on: April 02, 2020, 02:12:03 PM »
Bit more time on my hands tonight so started work on the back wheel
Just left with the rear hub but it will need a serious clean and polish before it’s fit for rebuilding with its new tim and spokes
Best wishes Al
Offline allankelly1
New project CB400/4
« Reply #18 on: April 05, 2020, 12:17:11 PM »
Hi all
Just been doing some small sideline jobs on the bike this weekend while I sort out the replacement cush drive bushes for the rear hub.
Restoring the rear foot pegs as they are very tatty
Ordered new rubbers and when disassembled found the little spacer plates missing
Like some other small parts they are no longer available but not to worry as it’s was an easy job to print up two replacement on the printer in black nylon
One job down but more to go.
Will try to sort out cush rubbers ASAP before they start to stop delivering stuff so I can build the back wheel
Catch up again soon and stay safe all
« Last Edit: April 05, 2020, 12:18:49 PM by allankelly1 »
