Author Topic: 1975 750 k5  (Read 1186 times)
Offline Halltm
1975 750 k5
« on: January 26, 2020, 06:40:20 AM »
New to the site.   Just picked up a 75 750 k5 from the original owner sitting since 91
Pulled the carbs off last night and yes the gas has carmelized and the gas in the tank looks like gold crude.   Working thru that....does anyone have a source for intake manifolds?  Or any other web sites
Thanks for your help in advance.
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: 1975 750 k5
« Reply #1 on: January 26, 2020, 07:59:23 AM »
David Silver Spares
Yamiya
Both have good supplies of parts and the parts are generally high quality. Don't get cheap ones.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline beemerbum
Re: 1975 750 k5
« Reply #2 on: January 26, 2020, 08:50:50 AM »
4 into 1 also a good source
Offline my name is nobody
  • I like Pontiacs and Hondas
Re: 1975 750 k5
« Reply #3 on: January 26, 2020, 09:16:35 AM »
Is it all stock/original? just curious...
Online Don R
Re: 1975 750 k5
« Reply #4 on: January 26, 2020, 09:19:06 AM »
 I've had some luck with lacquer thinner melting amber fuel from a gas tank. It will damage paint if you get sloppy.
Re: 1975 750 k5
« Reply #5 on: January 26, 2020, 09:21:56 AM »
I buy them from South Sound Honda, best prices and good delivery. They did start a $25 "handling" charge last year, so you need to buy enough stuff to make up the difference with their lower prices to come out well: in this case I would recommend getting both the 4 rubber hoses (2 of 2 different types) and a new set of carb-top linkage boots, as yours are likely cracked and broken by now. This will leave you about $4 "ahead" overall, based on the shopping I have done there.
Offline Halltm
Re: 1975 750 k5
« Reply #6 on: January 26, 2020, 04:04:31 PM »
Thanks.     It is all original
Re: 1975 750 k5
« Reply #7 on: January 27, 2020, 06:10:37 AM »
Red or blue ?
Offline Halltm
Re: 1975 750 k5
« Reply #8 on: February 09, 2020, 09:41:50 AM »
Blue
Offline Halltm
Re: 1975 750 k5
« Reply #9 on: February 09, 2020, 10:23:36 AM »
Any tips on where to get aftermarket needle jet holders?      Looking for something cheaper than the Hondas.     I cannot Screw off the main 105 jet off all 4 of these.
Thanks
Offline 69cb750
Re: 1975 750 k5
« Reply #10 on: February 09, 2020, 10:35:06 AM »
The needle jet goes in first then the main jet holders (with main jet)
Use vise if jet is stuck in holder.
Re: 1975 750 k5
« Reply #11 on: February 09, 2020, 11:20:40 AM »
There is 1 very good reason Honda carb parts are more expensive that the cheap china crap.
Trust me, you dont wanna try to save a few bucks by going that route...
Offline Halltm
Re: 1975 750 k5
« Reply #12 on: February 09, 2020, 11:41:56 AM »
Got them apart w the vice grips.    Good tip.   Going to clean up the ones I have.        Thanks
Re: 1975 750 k5
« Reply #13 on: February 09, 2020, 06:37:22 PM »
These guys are right!  ^^^
You will be much happier with the OEM jets, emulsifiers, and needles. They actually work...and when you reach about 105,000 miles, pull the main needle jets out and turn them 180 degrees and reinstall: they will have become slightly oval by then, but this makes them work like new again. ;)
Offline Halltm
Re: 1975 750 k5
« Reply #14 on: February 10, 2020, 05:14:27 AM »
Need float pins.    Any suggestions?
Also when I took out the needle jet holder I did not see the needle jet.   If it is still in the carb any thoughts how to punch this out.
Thanks for your help!
Offline 69cb750
Re: 1975 750 k5
« Reply #15 on: February 10, 2020, 05:39:56 AM »
Need float pins.   16126-259-004 https://www.ebay.com/itm/NOS-HONDA-CA175-CB77-CL175-SL350-FLOAT-ARM-PIN-PART-16126-259-004/232144422882?hash=item360ce2c7e2:g:IkkAAOSwXeJYKyCb
Try to push out with finger, else use plastic end of screw driver and tap gently.
Offline WhyNot2
  • I'm finally an
Re: 1975 750 k5
« Reply #16 on: February 10, 2020, 11:01:23 AM »
yep, be careful with those pins
Offline Halltm
Re: 1975 750 k5
« Reply #17 on: February 23, 2020, 04:13:06 PM »
Everything is out back and cleaned.    Replacing the gas lines.
Does anyone know the correct gas line size?
Also,   any tips on setting the floats?
Thanks
Offline Doobie
Re: 1975 750 k5
« Reply #18 on: February 24, 2020, 04:33:59 AM »
Thanks
Check the forum's manuals and tech docs section. Plenty of good info there, including a service manual.
You only go around once in life so it might as well be on a motorcycle.
CB550K4
CB750K2
CB750K2
CB750K6
CB750K6
CB750K7
CB750F3
CB900F2
Offline newday777
Re: 1975 750 k5
« Reply #19 on: February 24, 2020, 05:08:16 AM »
Thanks
5.5mm or you can use 1/4" fuel line.
Motion Pro 12-0052 Tygon Grey 1/4" x 3' Premium Fuel Line https://www.amazon.com/dp/B000WOHJIK/ref=cm_sw_r_cp_apa_i_AL8uEbN382JZ3
Float setting
https://www.vintagecb750.com/products/6/fuel-system/113/carb-floats-other-carb-components
Stu
My current rides
Prior bikes....
Offline newday777
Re: 1975 750 k5
« Reply #20 on: February 24, 2020, 05:13:46 AM »
Blue
My favorite. I bought one new in 1975. I have another now.
Stu
My current rides
Prior bikes....
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: 1975 750 k5
« Reply #21 on: February 24, 2020, 07:57:03 AM »
Hondaman's book
It's all in there.
Must have
Over
1973 CB 750 K3
