Author Topic: Speedometer Drive Grease (the clock, not the axle drive)  (Read 428 times)
Offline 34barab
« on: January 27, 2020, 08:23:45 PM »
Trying to rebuild a 750K1 speedometer.  Cleaned out all the old grease, now need to know what kind of grease to use on the drive.
Current Projects: 1973 CB750K3; 1972 CB350K4; 1980 CX500D;1969 CB750.  Roadworthy: 1971 CB750K1
Offline pjlogue
Re: Speedometer Drive Grease (the clock, not the axle drive)
« Reply #1 on: January 28, 2020, 12:52:56 PM »
When I rebuilt my tach and speedo I used PJ1 chain lube.  Sprayed some in a cup and used a tooth pick to apply it to all pivot points and the gears.  Once the carrier evaporated it stays put even at elevated temps when the bike may sit in the sun.  What ever you use, use it sparingly.  Don't forget the hub where the cable attaches.  The receiver/housing can squeal pretty bad if not lubed.
-P.
