The SOHC/4 World Tour is in under way.
... and only frame numbers on title
Cant be a K3 in 76 didnt come out till 77
Yes, it is a direct swap. The only wiring that connects directly to the engine is the charging system, starter, neutral light, and oil pressure sensor and all that should be identical regardless of model.
Quote from: seanbarney41 on January 29, 2020, 07:32:13 AM... and only frame numbers on title Not necessarily Sean. I bought a 550F on eBay from WI and the title had the engine number on it [and no frame number]Other members have reported the same too.
Quote from: Stev-o on January 29, 2020, 02:44:30 PMQuote from: seanbarney41 on January 29, 2020, 07:32:13 AM... and only frame numbers on title Not necessarily Sean. I bought a 550F on eBay from WI and the title had the engine number on it [and no frame number]Other members have reported the same too.yeah, I knew someone would bring up weirdo Wisconsin who was influenced by native Harley Davidson who put the vin number on the engine well into the eighties.
