Author Topic: Shoei Saddlebags installation  (Read 4665 times)
Offline ethan84
  • Motorcycle Rookie
Re: Shoei Saddlebags installation
« Reply #25 on: February 12, 2020, 08:38:18 PM »
I just received a pair of NOS Shoei SB-4’s in the mail today. Everything is there: original box, mounting instructions, all mounting hardware, and even the keys! If anyone would like some pictures of any of these things let me know.
My First & Only: 1972 CB750 K2 Brier Brown Metallic
« Reply #26 on: February 12, 2020, 09:09:01 PM »
A scan of the instructions attached here would be nice.
I think those bags are the same model my bike had in the 80's. Very stable in high speeds. Mostly 140-180 kmh on Autobahn and similar highways.
I had everything in plastic shoppingbags to keep water out from the clothes.
Offline Jarrett_Honda
« Reply #27 on: February 12, 2020, 09:10:09 PM »
I agree on scanning the instructions. I'm sure many more people would find it useful
Sent from my SM-N950U using Tapatalk
« Reply #28 on: February 12, 2020, 09:11:15 PM »
I ended up using a p clamp to attach the lower bracket.
Offline ethan84
  • Motorcycle Rookie
« Reply #29 on: February 13, 2020, 12:21:17 AM »
I’m currently working a 7pm - 7am shift... I will try to post pictures as soon as possible.
Offline mattsz
« Reply #30 on: February 13, 2020, 03:55:39 AM »
Amazing!  When I was looking for bags like these, I googled for about 2 hours, and there was one - count 'em - one set advertised for sale at the time.  And they were in Canada!  You just gotta be in the right place at the right time, I guess....
+1 on instructions.  Mounting brackets, too - even though they're probably not "universal."  Any details concerning the electricals (wiring, light sockets, etc) would be appreciated, too...
Offline ethan84
  • Motorcycle Rookie
« Reply #31 on: February 13, 2020, 05:46:24 AM »
Simple one page instructions:
Offline ethan84
  • Motorcycle Rookie
« Reply #32 on: February 13, 2020, 05:48:46 AM »
Closer view:
Offline ethan84
  • Motorcycle Rookie
« Reply #33 on: February 13, 2020, 05:51:22 AM »
Hardware:
Offline ethan84
  • Motorcycle Rookie
« Reply #34 on: February 13, 2020, 05:58:00 AM »
The keys with helmet shaped fob:
« Reply #35 on: February 13, 2020, 09:01:04 AM »
I did not have the frame clamps. The bracket with oval holes fitted direct to the passenger foot peg holes. Easy with 4-1.
« Reply #36 on: February 13, 2020, 06:19:59 PM »
I wrapped a liner of old tire tube rubber inside those clamps so they would not scratch the paint and metal. They also have a slight amount of 'give' to the mounting as a result.
Offline mattsz
« Reply #37 on: February 13, 2020, 06:38:27 PM »
 ;D
« Reply #38 on: February 14, 2020, 06:01:05 PM »
 ;D
Yeah....those were a throwback to the early Honda twins' rear pegs. I was always a little surprised that Honda did that. Again.
Offline mattsz
« Reply #39 on: February 14, 2020, 07:08:41 PM »
Stranger still that they "fixed" the non-USA 400's, but maintained the swinging arm mounts for us right to the end...
« Reply #40 on: February 15, 2020, 02:10:21 AM »
Going out for a ride tomorrow with the bags on. What should I expect from handling?
Offline Tracksnblades1
« Reply #41 on: February 15, 2020, 02:35:33 AM »
 ;D
The chain in the picture 👀, I can see it crying for lube.....
Age Quod Agis
Offline mattsz
« Reply #42 on: February 15, 2020, 03:07:53 AM »
Yes, you can!  That was taken when it was set out in the weather for a month or so by the PO - a year or two before I got it.  Maybe he was aiming for the chain, but only managed to lube the bottom of the engine...  ;)
« Reply #43 on: February 21, 2020, 08:55:19 PM »
3 weeks later I finally got the wire terminals I needed to connect the saddlebags' turn signal and brake lights.
Bad news is they were too big to fit perfectly in the terminals on the bike. I made them fit however with a bit of force.
I'm not sure why but the turn signals don't work when connected to the saddlebags. The brake lights work perfectly fine though.
I'm thinking that I might cover the wires leaving the bags in shrink wrap to protect them since they're exposed.
Offline ethan84
  • Motorcycle Rookie
« Reply #44 on: February 28, 2020, 01:33:05 PM »
Installed!
Offline ethan84
  • Motorcycle Rookie
« Reply #45 on: February 28, 2020, 01:35:38 PM »
Side view:
« Reply #46 on: February 28, 2020, 01:36:52 PM »
Side view:
Looks great!! I need to paint mine black.
Offline ethan84
  • Motorcycle Rookie
« Reply #47 on: February 28, 2020, 01:42:21 PM »
Side view:
Thanks! I hope to someday have everything paint matched, I just can’t decide to keep the stock brown color or do something a little more vibrant...
« Reply #48 on: February 28, 2020, 01:44:58 PM »
Side view:
How much flex do you have in your bags? I found mine to be surprisingly sturdy. Maybe it's due to that bottom bracket. I'm wondering it there would be an issue going over the 11lbs weight limit.
Offline ethan84
  • Motorcycle Rookie
« Reply #49 on: February 28, 2020, 01:55:51 PM »
Side view:
Even with the third point mounting bracket that most used sets seem to be missing they don’t feel as rigid as I thought they would. The Slight amount of wiggle  they have doesn’t seem to be cause for alarm though. I was able to put some miles in last Sunday before the snow returned and I didn’t notice anything out of the ordinary.
