Author Topic: Sandblasting the frame - masking the seat lock  (Read 1136 times)
Offline Jonm99
« on: February 06, 2020, 08:44:49 AM »
Hi guys,
I'm on the tail end of my build and preparing the frame for sandblasting and then powder coating. Any suggestions for how to mask the seat latch lock (specifically, the key hole) to safeguard it from the soda blast?
1977 cb750k with original airbox, PD41a carbs, slow jets=35, main jets=120, Delkevic 4in1 headers, 18" Cone engineering QC muffler, 7" headlight, dynatek ignition, ss r/r, clip ons, and ebc front brake rotor. All the rest stock, for now. First restoration, lots to learn!
Re: Sandblasting the frame - masking the seat lock
« Reply #1 on: February 06, 2020, 09:01:38 AM »
 Remove it?
Offline 69cb750
« Reply #2 on: February 06, 2020, 09:11:37 AM »
Remove it.
Offline jakec
« Reply #3 on: February 06, 2020, 09:19:46 AM »
Remove it.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline Scott S
« Reply #4 on: February 06, 2020, 11:36:28 AM »
 Or you could remove it.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline rocket johnny
« Reply #5 on: February 06, 2020, 01:11:57 PM »
+4
Online bryanj
« Reply #6 on: February 06, 2020, 02:58:06 PM »
Take it off ( just to be different!)
Offline scrambler
« Reply #7 on: February 06, 2020, 05:53:48 PM »
How about removing it?
Just kidding. You can also mask it off, but much easier and nicer just to remove it.
Offline Jonm99
« Reply #8 on: February 08, 2020, 10:16:20 AM »
It's a custom build and the lock housing has been welded into place, so unfortunately, removing it is not an option. How would I go about masking it before sandblasting?
Offline Steve_K
« Reply #9 on: February 08, 2020, 10:34:58 AM »
I mask taped my fork lowers before glass beading them.  The tape was in place when I finished, but I had to wash it 4 times with hot soapy water before I got it clean.  I would  not bead blast engine parts,  but masking and cleaning the lock should be ok.  Can you remove the key lock part and replace after painting?
Steve
Steve_K
Offline Scott S
« Reply #10 on: February 08, 2020, 11:22:42 AM »
 There's usually a little bit of grease inside the lock, for lubrication.  I would be concerned about it leaking out while it was in the oven. And then the lock would be dry inside.
 Is painting the frame an option?
'71 CB500 K0
'81 Yamaha XS650
Offline Tomshep
« Reply #11 on: February 08, 2020, 12:01:48 PM »
Locks can be re lubricated. Just grind it off and weld on a plate to take a conventional one before you get it blasted because if the welded on lock ever fails you will be stuck good and proper.
Online bryanj
« Reply #12 on: February 08, 2020, 12:46:20 PM »
But the lock housing is an alloy so how has it been welded?
Offline pmanning
« Reply #13 on: February 08, 2020, 05:24:50 PM »
Also be aware the VIN plate doesn't hold up well to sandblasting - not going to tell you how I know.
Offline XC204
« Reply #14 on: February 09, 2020, 04:44:24 AM »
Electrical tape works really good when sandblasting beads or sand just bounce off and it seals well to itself. Leaves no residue at least if you use a good brand like 3M.
« Last Edit: February 09, 2020, 04:47:07 AM by XC204 »
Offline Jonm99
« Reply #15 on: February 09, 2020, 07:33:07 AM »
Well... I guess I only needed 6 people to tell me to remove it, before I understood that I can simple remove it :-) I thought what I welded on to the bike was one unit, but apparently it was a plate + lock  :o
Thanks for the recommendation with the electric tape, that will come in handy to mask exposed threads (for ex. The rear shock mounts).
Thanks everyone, looking forward to getting this beast back into one piece!
« Reply #16 on: February 09, 2020, 03:30:08 PM »
I was going to suggest remove it...
Offline Jonm99
« Reply #17 on: February 09, 2020, 08:57:47 PM »
lol  ;D
