Author Topic: Cb550 Tacho  (Read 1124 times)
Offline emilios
Cb550 Tacho
« on: February 06, 2020, 09:11:24 AM »
Hello
Im going to install a Velona Speedo on a Cb500 1977
Its a cafe racer that im building for a friend..
This speedo has also a display rpm..
In the instructions it says to install the "white wire" on the 12v supply on the coils so it can read the pulse
Why i think that is wrong?
Pulse is not coming throught the points?
BTW i have install electronic ignition..
Its the second speedo(velona) that im going to install..The first one was suddenly die..and i dont remember sure but im afraid was when i install the rpm wire on the 12v supply..
Anyone had any idea what i could do?
Thanks in advance
Re: Cb550 Tacho
« Reply #1 on: February 06, 2020, 02:56:40 PM »
I dont thonk you can make that work with electronic ignition
Re: Cb550 Tacho
« Reply #2 on: February 06, 2020, 08:46:47 PM »
The instructions may be referring to a "CDI" type electronic ignition, which pulses the positive side of the coil, while our ignition systems switch the negative side of the coil, whether electronic or points. There should be an "inductive" option which uses a wire wrapped around a spark plug wire to provide the pulse for the tachometer function.
