« Reply #34 on: September 05, 2023, 03:24:45 AM »
Thanks all, I appreciate your compliments. Next sub-project on the agenda is to build a good fuel tank using the tank that came with the bike and a donor tank. When I removed all of the bondo from my tank that came with the bike, I found that a major repair had been done previously on the near side front of the tank. The PO had accessed the inside tank area by cutting an access hole on the inner side of the tank. Unfortunately the tank is now not 'true' after the repairs. The attached photos better show what I am alluding to. The donor tank (blue tank in photos) has some large dents on the upper surface but it has a great lower pan. If I can't repair the donor tank then I will unzip the bottom pan from the donor tank and graft it onto the other tank (grey tank in photos). Anyway a plan is a basis for change so stay tuned for future updates on this tank repair.
How did you unzip the seams? Someone else was asking if anyone had done a tank repair.
Any further progress reports on the bike?
Logged
Stu
My current rides
Prior bikes....
