Author Topic: Rebuilding steering, will this kit be sufficient? K7 750  (Read 1174 times)
Offline Pielz
« on: February 22, 2020, 04:50:59 pm »
I'm looking to replace and refurb my steering bearings. It's not rough and doesn't feel terrible, Im just getting a new triple and figured I'd better. I'm wondering if this kit will have everything I need to replace seals, etc. I noticed today down by the bottom of the headstem there's a rubber seal poking out partially from the last rebuild, whenever that was.
https://www.ebay.com/itm/183127608862
Re: Rebuilding steering, will this kit be sufficient? K7 750
« Reply #1 on: February 23, 2020, 12:13:43 am »
That kit has all you will need
Offline Erny
« Reply #2 on: February 23, 2020, 03:18:10 am »
I used AllBalls kit 22-1011 on 2 bikes already K7 750 and K1 550. kit has all you need. https://www.allballsracing.com/catalog/product/view/id/446. You can find it on ebay or elsewhere cheaper.
Warning - you have to fix higher upper bearing by grinding ridges of upper nut (pos 16) otherwise you won't have enough thread for nut. Additionally you might need to fix small gap between top yoke and headlight brackets (you will be 1-2mm higher) by rubber/steel washer/O-ring or another way.
Described here http://forums.sohc4.net/index.php/topic,1516.msg1605853.html#msg1605853
But all in all, installting this tappered bearing is HUGE improvement compare to stock on all bikes I did. And does not require maintenance as legacy one later on.
CB750K K7 USA model (1977)
CB550K1 USA model (1975)
Offline Pielz
« Reply #3 on: February 27, 2020, 05:23:47 pm »
Would someone be able to tell me the size of these ball bearings inside the steering stem? I'm not sure if I dropped one, or it was short one to begin with, but I'm down 1 ball. Upon checking out the state of these races, I'm just going to stick with the current setup.
I'd like it if I could order it with prime shipping and I knew the size.. but I have a feeling they're not going to be something easy to track down
Offline Pielz
« Reply #4 on: February 27, 2020, 05:41:24 pm »
Also, any theories as to why I don't have a VIN stamp? Lol
Offline BenelliSEI
  • 1969 cb750
« Reply #5 on: February 27, 2020, 06:41:09 pm »
That is odd! Vin plate on the other side?
Offline rotortiller
« Reply #6 on: February 27, 2020, 06:47:32 pm »
but I'm down 1 ball
The lower race has one additional ball FYI
Offline Pielz
« Reply #7 on: February 27, 2020, 06:58:44 pm »
Yep! There's a VIN plate. It's been glued on, not riveted. I honestly can't see any grinding marks from it being ground off. No VIN under the plate either
Offline Pielz
« Reply #8 on: February 27, 2020, 06:59:20 pm »
but I'm down 1 ball
Unfortunately I have 36 total. Know of a way I can get 1 more without ordering a kit off eBay?
Offline rotortiller
« Reply #9 on: February 28, 2020, 04:39:26 am »
Find a bearing with the same ball size and crack it open. I bet someone has balls that were replaced by tapered rollers. I have some at my brother's digs but he is away for a month. I bet someone close to you is in a similar situation as I with old balls to spare.LOL
BALL STEEL #8 CB750K7 FOUR CANADA
The 9621108000 Ball Steel #8 can be ordered. View linked machines. 96211-08000 is the manufacturercode.
« Last Edit: February 28, 2020, 04:46:36 am by rotortiller »
« Reply #10 on: February 28, 2020, 06:04:56 am »
 I think the steering balls are 1/4" in size.
Offline Pielz
« Reply #11 on: February 28, 2020, 07:35:07 am »
Thanks guys! They look to be pretty close to a quarter inch. Calipers broke or id check lol. Might just bite the bullet and order a pack. I dropped a few when removing the triple as I didn't have a magnet handy and I lost count as they fell so I'm not sure if I'm even searching for one that exists on my garage floor. Might have been short one to begin with on the bottom race
Offline Pielz
« Reply #12 on: February 28, 2020, 01:48:06 pm »
100 1/4" Campagnolo Shimano Hub Bracket Bike Loose Bearing Balls https://www.amazon.com/dp/B006PR7Y3I/ref=cm_sw_r_cp_apa_i_aOywEbA8YBAHE
This is what I bought since the races still look nice
Offline Pielz
« Reply #13 on: March 02, 2020, 12:42:29 pm »
As you can see theres a little room between the top of the fork covers and the top bridge. Is that normal or do I not have my triple far enough inside the stem? Everything tightened down okay inside and the top acorn nut has the perfect amount of threads.
« Reply #14 on: March 02, 2020, 02:05:36 pm »
Where are the topand bottom rubbers  ? I know all the early ones used them..
Offline rotortiller
« Reply #15 on: March 02, 2020, 03:00:43 pm »
Stick an o-ring in there at the bottom hidden from view if it rattles at the stock fork ear rubbers or you want the gap gone.
Offline Pielz
« Reply #16 on: March 02, 2020, 04:11:49 pm »
I actually just received these fork ears in the mail from another user and since my bike didn't have the stock fork ears originally, I wasn't aware that it needed them. He's actually going to send me a pair, I guess the 77 and 78 models only used rubber grommets at the tops of the fork ears
Offline rotortiller
« Reply #17 on: March 02, 2020, 04:32:11 pm »
A  look at the online parts manual is a good way to find out what you are missing rather than making a guess.
upper rubber 2 required
lower rubber 2 required and cost about 3 bucks each
Offline Pielz
« Reply #18 on: March 02, 2020, 04:50:06 pm »
Ah. Sorry I've been at work all day. I searched them on eBay quickly and the listing only said 2 were required. Yeah, I'm wrong about that. Hondapartshouse.com definitely says there are ones for top and bottom
Thanks for the correction!
« Last Edit: March 02, 2020, 04:51:53 pm by Pielz »
