Author Topic: Shortening forks CB550  (Read 347 times)
Offline nlekij
    • https://myloweslife.onl/
« on: February 24, 2020, 08:46:14 AM »
I’m going the spacer and cut spring route. Question on the spacer. Would a copper spacer react and corrode in contact with steel or will the fork oil prevent that? I was going to use pvc but the outside diameter will not allow it to slide inside the fork tube.
Re: Shortening forks CB550
« Reply #1 on: February 24, 2020, 10:21:14 AM »
Copper is used as a seal on fork drain bolts.  And other steel parts.
