Hello all,
I started the bike (78 CB550K) for the first time after the mild rebuild and I'm seeing 14.95 volts at around 4500 RPM. I installed a new regulator/rectifier combo unit. The battery is good. When I fully charge the battery I'm getting 12.9 Volts. Is 14.95 volts too high? I can try putting the old OEM rectifier and regulator back on and measure the results.
Thanks!
