Author Topic: plugging ports  (Read 747 times)
Offline beemerbum
plugging ports
« on: February 25, 2020, 08:35:23 am »
I want to pressure wash my 750 motor before I start some disassembly. The exhaust and carbs are off. What would be an effective way to plug uo the intake and exhaust ports?
Offline pjlogue
Re: plugging ports
« Reply #1 on: February 25, 2020, 08:56:47 am »
When I prepped my motor for cleaning and painting I used 1.25" (I think that was the size) rubber end caps with hose clamps.  The kind you find in the plumbing section a Lowes/Home Depot.  Make sure your exhaust nipples are seated tight otherwise the water can get in where the coper crush washer is.  I would avoid directly blasting the rubber caps just in case.
-P,
Offline newday777
Re: plugging ports
« Reply #2 on: February 25, 2020, 12:38:33 pm »
-P,
1 1/2" exhaust. 1 7/16" intake
Stu
My current rides
Prior bikes....
Offline CaptFatCat
Re: plugging ports
« Reply #3 on: February 25, 2020, 01:01:32 pm »
I use the mushroom shaped corks from my wifes wine bottles. they fit perfect and seal air tight. and she has plenty of them!
Resurrecting a Herman Munster CB750 from a few old baskets of K2 and K7 parts.
Re: plugging ports
« Reply #4 on: February 25, 2020, 06:04:21 pm »
I used condoms on the exhaust spigots one time...seriously!  They worked too!  Plus, you can turn the engine with the kickstart and do a condom inflation compression test. lol
Offline Jeff10
Re: plugging ports
« Reply #5 on: March 01, 2020, 10:23:33 pm »
Here is how I do it.
Offline beemerbum
Re: plugging ports
« Reply #6 on: March 02, 2020, 01:52:13 pm »
What is the size of the rubber plugs in the exhaust?
Offline Jeff10
Re: plugging ports
« Reply #7 on: March 03, 2020, 10:39:19 am »
Size 8, #52039 Hillman Rubber Stoppers (I think Lowes has them in the US). Top size is 1-5/8, bottom is 1-5/16.
