I’m working on a CB350G twin, but as the front and rear hubs/bearings/seals are identical to those on the CB350F (same part numbers, etc):
I’m doing the wheel bearings/seals. The bearings themselves are done, but I had a couple of questions on the seals. This is the first time I’ve done this.
I’m using the all balls kit, which comes with four seals. One each for the front and rear wheel, obviously. It appears the third is for the speedo drive, and I’ve no idea what the fourth is for. Here are the sizes of the old/new seals, where all values are what was embossed/stamped/whatever on the seal:
Rear
Old: 30x45x9.5
New: 30x45x10
Front
Old: 22x35x8
New: 22x35x8
Speedo
Old: 34x48x7
New: 35x48x8
Unknown
40x50x6
Questions:
1. Does the .5mm diff on the rear bearing seal matter? Read: is it ok to use or should I try and source one in the original size?
2. Are folks using the supplied speedo drive seal, or attempting to source the original size? If so, where y’all getting them? SKF doesn’t appear to offer a seal in the original dimensions. eBay has some, and I found this:
Dichtomatik Americas - 34X48X7TCExtra credit: I know nothing about bearing seal design, but the SKF catalog shows multiple designs for each set of dimensions. What type of seals are these?
Thanks.
