Author Topic: Help identifying my tank and petcock  (Read 678 times)
Offline Nicklopic
  • New York
« on: March 01, 2020, 04:42:07 pm »
Could anyone identify what my tank and petcock is off of? I think it's maybe from a 400 but I do not know for certain.
I need to order a new cap seal and rebuild the petcock or get another.
It's been modified obviously as you can see by the relocated petcock and mount.
Photos below, thank you for any help.
80' CB650
Build Thread
Offline setdog
Re: Help identifying my tank and petcock
« Reply #1 on: March 01, 2020, 06:55:04 pm »
tank cb 360 ?  // petcock no idea
looks like it was modified to fit a chopper or just to bolt to frame, guessing tho
« Last Edit: March 01, 2020, 07:10:55 pm by setdog »
My toolbox consists mainly of hammers.
76 CB 200T. (sold)
75 CB 750 K5. (sold)
74 CB 750 K4. (current rider)
73 CB 750 K3. (build)
https://www.youtube.com/user/setdog100
« Reply #2 on: March 01, 2020, 07:37:51 pm »
+1 on cb360
Offline Nicklopic
  • New York
« Reply #3 on: March 02, 2020, 09:57:06 am »
Looks like you guys were spot on with the 360 tank. I know its been modified and its currently on my 650.
For the hell of it I checked what the petcock looks like on 80 650 and it looks like its an OEM non vacuum petcock from one. I probably should have guessed that was the case, but I had no idea.
Thanks for the helppppp
80' CB650
Build Thread
« Reply #4 on: March 02, 2020, 11:13:08 am »
Your gun in the way makes it hard to id. I suspect 450 or 350/360 .
 They have crossover tubes . On this one there appears to be one welded over ,and the second one, well gun is in the way.
 Without crossover , you any be leaning it over a few times when into reserve.
 The 450 CB tanks , are like ssmaller version of tge 750 tank, and look good on them, shows more motor.
Offline Nicklopic
  • New York
« Reply #5 on: March 02, 2020, 12:01:20 pm »
ah adding a crossover again would be a good idea. ill get to that eventually. and my bad, I didn't realize the placement of the thermometer. ill look for a welded bung tonight
80' CB650
Build Thread
« Reply #6 on: March 02, 2020, 01:38:10 pm »
They werea formed tube. If you do 're install you may want to relocate. Pain in the butt when you remove the tank.
Offline Nicklopic
  • New York
« Reply #7 on: March 02, 2020, 08:22:35 pm »
I checked the underside tonight. Nothing welded closed on the other side. It looks like the petcock was just moved from it's original position.
It also seems it's not a 79-80 650 petcock. Very similar but my threads are 16mm instead of 14. I'm guessing the 81-82 nonvacuum might be the ticket but I'll have to find out for sure
80' CB650
Build Thread
