Author Topic: Which Carburetor vacuum gauge set  (Read 786 times)
Offline Ridgerun
« on: March 08, 2020, 09:27:23 AM »
This has probably been asked many times before, but what 4 gauge carburetor vacuum gauge set do you recommend.....
Offline ckahleer
Re: Which Carburetor vacuum gauge set
« Reply #1 on: March 08, 2020, 09:51:00 AM »
I have one of those liquid column type gauges. If I were to replace it, I would go with mechanical dial gauges.
Too much fiddling with getting fluid heights zeroed, and relearning how to use something I use less than once/year.
Online bryanj
« Reply #2 on: March 08, 2020, 10:35:53 AM »
Sealey is what i bought
Offline Johnie
« Reply #3 on: March 08, 2020, 11:26:26 AM »
The Morgan Carbtune is very popular here. I have used the Morgan for 15 years and does an excellent job.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #4 on: March 08, 2020, 01:42:21 PM »
Factory Honda vac gauges are my go-to, but can be hard to find...
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #5 on: March 08, 2020, 02:13:30 PM »
I’ve got an extra Morgan’s under my bed.
Online bryanj
« Reply #6 on: March 08, 2020, 02:48:04 PM »
If you can find Honda they are megabucks, the Sealey are identical as far as i can see but a lot cheaper, the sets of four on blue steel with plastic tee as dampers are not worth buying
Offline carnivorous chicken
« Reply #8 on: March 09, 2020, 07:15:41 AM »
Morgan Carbtune for me too.
I had a mercury gauge for years and like it a lot, but you've got to be careful to keep it upright.
I had a motionpro blue liquid tool fo a while, that thing was horrible -- bubbles, fluctuations.
Best bang for your buck these days is the Morgan IMHO.
Offline ckahleer
« Reply #9 on: March 09, 2020, 05:42:19 PM »
Is there no liquid in the Morgan? Is it accurate held at any angle?
Offline Johnie
« Reply #10 on: March 09, 2020, 06:39:26 PM »
No liquid in the Morgan. You hang it on the handlebars.
« Last Edit: March 09, 2020, 06:44:01 PM by Johnie »
Oshkosh, WI  USA
Online BenelliSEI
  • 1969 cb750
« Reply #11 on: March 10, 2020, 05:39:01 AM »
I have an old Motion Pro that works great. But, I’d get the Morgan, if shopping today.
If anyone wants to foolishly spend money (see EBay link above), I have a perfectly restored set of 1971 Honda gauges!
« Last Edit: March 10, 2020, 05:53:46 AM by BenelliSEI »
Offline Kelly E
  • Geriatric Hooligan
« Reply #12 on: March 10, 2020, 06:22:11 AM »
I use a DigiSync for carb tuning. Four channel and a built in tach. They also have a six channel for the Goldwing and CBX guy's.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline rotortiller
« Reply #13 on: March 10, 2020, 06:33:24 AM »
It really does not matter which set of four you buy so long as you match them ideally at the operating range or position. Very simple to do too, no rocket science needed. Easier to cal when indicators are not bouncing and from an uninterrupted source of vacuum.
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« Reply #14 on: March 11, 2020, 06:28:27 AM »
+1
cb750 k6 - ugly
Offline Doobie
« Reply #15 on: March 11, 2020, 08:17:32 AM »
Another +1 for the Morgan. Works well and comes with a variety of adapters and a case.
You only go around once in life so it might as well be on a motorcycle.
CB550K4
CB750K2
CB750K2
CB750K6
CB750K6
CB750K7
CB750F3
CB900F2
« Reply #16 on: March 11, 2020, 10:17:07 AM »
+3 Morgan;) easy to compare  all 4 side by side.
Set  valve lashes and ignition before.
Ignition  especially if you use points. The easiest way to set points equally is with a dwell meter, then timing lamo and most likely dwell again adjusting points on an idling engine.
I'm sure you will find it running well after proper ign,  less need of carb adjustments.
