Author Topic: 78 CB550 PD46A carb slide set screw??  (Read 649 times)
Offline 78cbfun
« on: March 08, 2020, 03:37:27 PM »
Guys who happens to know the size of then slide adjustment set screw for 78 cb550 with PD46 carbs.  Caliper measures it 5mm ?? 5mm 40 thread count?  A standard 5mm at local parts stores do not fit, the major diameter is shy of 5mm.
« Last Edit: March 08, 2020, 06:05:46 PM by 78cbfun »
Offline 78cbfun
Re: 78 CB550 PD46A carb slide set screw??
« Reply #1 on: March 09, 2020, 07:20:44 PM »
For those who don’t know, the set screw is a 5mm-0.5,  I have found only one company who makes them as a set screw and not a an Allen bolt head.
