Author Topic: engine paint  (Read 1026 times)
Offline tlbranth
engine paint
« on: March 08, 2020, 05:05:23 PM »
Just about to prep and paint my CB750 engine - cases, barrels and head. Any recommendations on which paint to use?
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline jaytee-nz
Re: engine paint
« Reply #1 on: March 08, 2020, 07:47:17 PM »
I've used Duplicolor with the ceramic in it and found it goes on easily and is durable. Best thing about it is that you don't need to heat the cases afterwards to cure it.
Offline Kevnz
Re: engine paint
« Reply #2 on: March 09, 2020, 02:49:29 AM »
Just as a matter of interest, which parts of the motor are painted? Obviously not the polished bits, but are head and barrel painted or left natural alloy? I know rocker cover is, ditto main cases. I painted my 500 cases years ago, someone suggested mag wheel paint. Over the years, leaky carbs have taken their toll, don't want to have the same problem with my 550.
BTW, I just noticed an old post about whether 550's came out in Freedom Green. I've just stripped the original tank on mine and FG was indeed the original colour.  FYI, the side cover badges are of the same style as the 500, not the more ornate ones that seem to have been fitted to the US models.
Good grammar: The difference between knowing your #$%* and knowing you're #$%*
Offline jlh3rd
Re: engine paint
« Reply #3 on: March 09, 2020, 03:44:39 AM »
1974 550 KO.....U.S. import...freedom green metallic.....honda identification guide.
Offline BenelliSEI
  • 1969 cb750
Re: engine paint
« Reply #4 on: March 09, 2020, 06:14:43 AM »
In Canada, I buy a Dupli-Color Engine Enamel. Can is marked “CDE1615 Aluminum”. Not a perfect match, but very, very close! They also make matching primers, that I have used. Engines smoke off a bit the first few cycles, but then it becomes very durable and long lasting. Like anything else you paint, the devil is in the detail. Takes a few minutes to paint, days to prep it......
Offline pjlogue
Re: engine paint
« Reply #5 on: March 09, 2020, 07:15:07 AM »
I have used this:  https://www.eastwood.com/eastwood-ceramic-engine-paint-universal-aluminum-quart.html   on two engines.  The color is almost identical to original case paint.  (I can't tell the difference)  I use it with the activator and dilute with 10% Xylene.   The finish is very durable and withstands hot gas and solvents under normal use.  I made sure my cases were very clean and gave a wipe down with Acetone to remove any trace of oils.  Going on it will look like it has patterns in the metallic but upon curing the patterns disappear unless you really glob it on (have slumps)  It dries to the touch in about 3 hrs and can be handled after 5 hrs.
-P.
Re: engine paint
« Reply #6 on: March 09, 2020, 08:38:50 AM »
+1....this works fine.
Offline tlbranth
Re: engine paint
« Reply #7 on: March 09, 2020, 10:23:11 AM »
I did paint my oil pan and oil filter cover a few years back and they held up well but I didn't write down what I used. I'm going to paint the whole engine semi-gloss black. Does the Duplicolor hold up OK on the head and cylinder block?
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline BenelliSEI
  • 1969 cb750
Re: engine paint
« Reply #8 on: March 09, 2020, 10:35:21 AM »
Yes.....  cleaned everything really well. It’s lasted for years!
Offline jaytee-nz
Re: engine paint
« Reply #9 on: March 09, 2020, 12:42:12 PM »
Been on my entire engine for 4 years and still looks great.
As with any painting though, preparation is the key so you need remove all oil, grease etc. beforehand.
I used lots of degreaser and then put the cases in our dishwasher through a couple of cycles (while the wife was away of course).
Offline scrambler
Re: engine paint
« Reply #10 on: March 09, 2020, 04:01:17 PM »
I think I used the same engine paint on my Yamaha and it was durable and nice for long, however, once when the float valve got stuck open the gas washed it off ... So for the CB I had it powdercoated, that`s fuel resistant for sure.
Offline jaytee-nz
Re: engine paint
« Reply #11 on: March 09, 2020, 04:30:03 PM »
I've spilled gas on my paint and it didn't wash off - wonder if the ceramic in it helps ?
Re: engine paint
« Reply #12 on: March 09, 2020, 10:19:20 PM »
My CB750's got Motip engine paint, rattle can color aluminium. Color very close to Honda.
I could not see a difference compared with starter compartment I did not paint.
It withstand fuel very well. I have done some carb jobs on my K6.
Easy to repair under the carbs that got scastches. Cleaned with acetone, covered carbs, side covers with tissues and sprayed a little and surface back in nice shape again.
This paint is not that thick and it will look like a stock engine with the structure shining thru. 2k painted cases I have seen look like engine has been dipped in paint. Not as Honda delivered them.
Offline Shtonecb500
    • Youtube profile
Re: engine paint
« Reply #13 on: March 10, 2020, 05:32:23 AM »
I used Duplicolor enamel, whichever color you like. Then I used 2k clear coat.
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
Offline scrambler
Re: engine paint
« Reply #14 on: March 11, 2020, 10:10:37 AM »
I dunno, didn`t work out for me. I used clear coat on it though. Off topic, how`s your TX?
Offline jaytee-nz
Re: engine paint
« Reply #15 on: March 11, 2020, 11:56:05 AM »
Well after getting it run well, it still leaked oil out of many of the new seals, so I sold it. Actually made a few thousand bucks so in the end I was happy.
Offline scrambler
Re: engine paint
« Reply #16 on: March 11, 2020, 03:20:00 PM »
Yeah, sounds familiar, I`m still struggling with those leaks, they have to end at some point. Yours looked awesome, no surprise you could sell it with profit.
