Author Topic: Steering Lock removal  (Read 934 times)
Offline Register
« on: March 08, 2020, 11:34:27 PM »
I need some advice on the best way to remove the steering lock please.
Its off the bike but I do not have the key.
Thanks
Re: Steering Lock removal
« Reply #1 on: March 09, 2020, 01:22:24 AM »
If you dont have the key you will have to drill it out
Offline pjlogue
« Reply #2 on: March 09, 2020, 02:00:07 AM »
What bike?  Year and model?  If the fork is unlocked and it is an early bike (lock under steering head) taking the cover off, the lock should drop out.
-P.
« Reply #3 on: March 09, 2020, 05:12:28 AM »
Not without the key to turn it it wont
Offline pjlogue
« Reply #4 on: March 09, 2020, 06:05:41 AM »
On the early bikes where the steering lock is under the neck, the lock core has to come out one way or the other and it most certainly won't come out if it's in the lock position.  The roll pin in the side of the cylinder is what keeps the cylinder from coming out when the head is locked.  When unlocked, the roll pin is in line with the wafer stack and should just slide out of the head once the cap is removed.
-P.
« Reply #5 on: March 09, 2020, 06:19:29 AM »
You put the key in then turn it before you can push it in, turn it back and remove key.
The pin stops the lock moving in or out when it is fully in(steering locked) or fully out (steering free)
Offline pjlogue
« Reply #6 on: March 09, 2020, 07:05:00 AM »
Thanks for the correction and explanation.  I don't think I have locked the steering on my bike since I restored it and obviously forgot how it worked.  LOL.
-P.
« Reply #7 on: March 09, 2020, 07:55:43 AM »
Made no difference on my 500, the local scroats still stole it!
