Author Topic: CB350 twin with cable-mounted front brake light switch  (Read 3956 times)
Offline Cowboy
« on: February 08, 2007, 10:14:29 AM »
My 1970 cb350 twin has front drum brakes, and the cable that operates the front brakes has a switch mounted partway down the cable, to activate the brake light. I want to replace the cable. I see lots of replacement cables for cb350s available on ebay, and not one of them has this switch mounted on the brake cable.
Did Honda use a different system to activate the brake light on later cb350 twins, and is it easily adaptable to my earlier model?
1964 Honda CT200
1967 Chang Jiang 750 Sidecar
1970 Honda CB350
1978 Honda CB550
Offline Raul CB750K1
Re: CB350 twin with cable-mounted front brake light switch
« Reply #1 on: February 08, 2007, 10:56:18 AM »
My CB350 K4 has a switch mounted in the brake lever housing. I just bought it a couple of weeks ago (OEM) for my restoration, it was about 10 euros.
Offline Cowboy
« Reply #2 on: February 08, 2007, 03:47:36 PM »
I guess I could switch to that sort of brake lever housing if I can't find the proper cable, or I could probably cut a cable sheath and manage to install my old switch on a new cable.  With that thought in mind, last night I started practicing casting the end onto a cable. I need to carve a better mold and try again tonight.
1964 Honda CT200
1970 Honda CB350
1978 Honda CB550
Offline Cowboy
« Reply #4 on: February 09, 2007, 11:19:03 PM »
Ouch is right!  I just paid less than that for three entire SETS of Brake,throttle and clutch cables!  I think I'll give my cable building skills a try!
1964 Honda CT200
1970 Honda CB350
1978 Honda CB550
Offline chung
  • Giddy Up
    • chungfucycles.com
« Reply #5 on: February 10, 2007, 05:55:11 PM »
Dude, That's not really that bad a price considering that you are going to have to remove/replace your switchgear housing to use the other type of switch or go to a lotta work to MFG one from your broke one. And you still have to buy a cable to do the swap. A black generic replacement w/out the switch has gotta be near $30 from MOTION PRO?
And It's grey, not black!!!
Buy it while you can get it, it'll last another 30 years ::)
IMHO
Member#2815
1971/76 CB750 Hack @970cc,
1975 CG750K
1970 CB350,
1972 YDS7, 250
1972 YR5, 350
1977 RD400,
1978 Piaggio Grande/Batavas HS50 Special
1981 XS650 Special II
