Author Topic: Is fuel flow the same flow rate across the dual barbs petcock?  (Read 348 times)
Offline DesertKyorugi
  • '87 GS450 '86'87 ZL600 '73 CB500 '70 '71 '71 CB750
I just rebuilt the petcock off my 71 JDM CB750 and was checking for obstruction. I noticed the rearmost barb is flowing faster than the forward barb. Is that supposed to be correct or am I having so blockage issue? I blew compressed air into both barbs and still get the same results
US '71 CB750K1 Stored for 39 years, currently running
US '71 CB750K1 Currently running
JDM '71 CB750K1 Stored for 21 years, currently running
US '70 CB750K0 Stored for 28 years, currently in restoration
US '70 CB750K0 Stored for 43 years, currently in restoration
US '70 CB750K0 Currently waiting to be restored
US '73 CB500K2 Stored for 40 years, currently running
Re: Is fuel flow the same flow rate across the dual barbs petcock?
« Reply #1 on: March 10, 2020, 05:14:42 PM »
Try this when observing flow...plug one outlet and it all comes out the other, plug the other outlet and it all switches to the first.  Fluids are gonna take the path of least resistance.
Offline BenelliSEI
  • 1969 cb750
« Reply #2 on: March 10, 2020, 05:25:49 PM »
...... and what you observed is “normal”.
« Reply #3 on: March 10, 2020, 05:58:46 PM »
Very interesting.....that means I have the fuel hoses routed wrong on my other 71 K1. I should route the rearward barb to carbs 1-2 instead since it has the longer route.
« Reply #4 on: March 10, 2020, 06:11:59 PM »
  I had once considered porting the slower flowing side but try to avoid fixing non existent issues. Desert may have it right, the longer hose could use a head start.
Offline BenelliSEI
  • 1969 cb750
« Reply #5 on: March 11, 2020, 05:35:29 AM »
But here’s the thing; if you even slightly restrict the flow at the pipe that appears “more”, the other one’s flow will increase. We’re only topping up the float bowls, at the rate fuel is being consumed. There is plenty of volume, and it get’s shared as required (assuming your filters are clean and openings unobstructed). Also, make sure the fuel cap vent is clear. If it’s plugged, nothing works.
« Reply #6 on: March 11, 2020, 09:27:29 AM »
I have clear fuel filters on my running K1. The right bank filter always gets filled up first, which I contributed to having a shorter route but now I know it is both shorter route and faster flow.
I will switch the hoses and see if it allows both to get filled up at the same time
