Author Topic: Oh dear ...  (Read 75633 times)
Re: Oh dear ...
« Reply #125 on: November 17, 2020, 11:22:53 AM »
Making them greate again will cost some ;)
Offline 69cb750
Re: Oh dear ...
« Reply #126 on: November 17, 2020, 12:58:43 PM »
Making them great again will cost some
No kidding, would that be MMGA or MHGA or MCBGA, quite a few choices.
Re: Oh dear ...
« Reply #127 on: November 21, 2020, 06:50:39 PM »
Later 392 K7 pistons to get some extra CR?
Looks like it. That was a "hop up mod" in 1980. :)
Today you can take the CB750 DOHC stock-bore pistons and cut a 1/2" flat around their outer edge (of the crown) to clear the valves, and net a 9.6:1 CR in the early heads (with a 1.0mm overbore, first).
Are you saying the dohc pistons into the sohc? Are you doing this mod? I didn't see it on the website.
Yep, have done a couple of them, have one set of pistons still left from that "run". The stock-size bore of the DOHC engine is 1.0mm overbore in our SOHC engines (62mm) and the wristpinis the same size. The valves can touch the pistons, though, unless you relieve the new pistons -0.5mm for a band of 13mm (1/2") around the outside of the tops. Then it leaves a penta-roof piston in a hemi head, which cuts down on the overlap breathing a little bit. This leads to higher compression with a crisp low-end torque, but requires premium gas be used because of the high compression and lack of swirl-charge action (the middle ridge of the piston breaks up the swirl).
I was doing these back before CruisinImage started making the post-1975 pistons for us. Now you can buy a set of his pistons for less than the machine work on the ones I have!
Re: Oh dear ...
« Reply #128 on: March 09, 2021, 04:45:05 PM »
FYI - This bike needs to be "seconded" to be eligible for Bike of the Month (renomination) in the following thread:  http://forums.sohc4.net/index.php/topic,180400.0.html
Re: Oh dear ...
« Reply #130 on: March 10, 2021, 07:34:31 AM »
Either link is broken or listing is gone...
Offline 69cb750
Re: Oh dear ...
« Reply #131 on: May 20, 2021, 09:27:45 AM »
Returning soon with a CB750 story, having some minor H2 problems ...
Tequila Sunrise (2013 Remaster) -
Offline 69cb750
Re: Oh dear ...
« Reply #132 on: May 20, 2021, 09:28:36 AM »
Offline 69cb750
Re: Oh dear ...
« Reply #133 on: May 20, 2021, 09:29:21 AM »
Offline 69cb750
Re: Oh dear ...
« Reply #134 on: May 20, 2021, 09:30:04 AM »
Re: Oh dear ...
« Reply #135 on: May 20, 2021, 11:02:49 AM »
Yikes!!
Re: Oh dear ...
« Reply #136 on: May 20, 2021, 11:32:48 AM »
Cylinder bore! Boring job but it will be fun to see when ready.
I'm sure it will look like a new bike.
Re: Oh dear ...
« Reply #137 on: May 21, 2021, 06:20:19 AM »
1972?   Thats a valuable bike even in that condition.
My '74...
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Oh dear ...
« Reply #138 on: May 21, 2021, 09:05:54 AM »
I hate to see these old bikes left to deteriorate.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline Davez134
Re: Oh dear ...
« Reply #139 on: May 21, 2021, 03:38:20 PM »
Excited to see this one! I really want to restore one of these, just can't find one anywhere near me.
Offline 69cb750
Re: Oh dear ...
« Reply #140 on: May 21, 2021, 05:45:57 PM »
1972?   That is a valuable bike even in that condition.
1972 H2, bikes like this used to cost $100 not that long ago ...
They appear on ebay on a regular basis.
I have machined pistons out of bores before.
The cylinders are stuck on the studs (12), nine down three to go (wore out two cobalt bits, broke two carbide bits).
Offline 69cb750
Re: Oh dear ...
« Reply #141 on: July 02, 2021, 12:50:01 PM »
Oh dear ...
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Oh dear ...
« Reply #142 on: July 02, 2021, 09:46:18 PM »
I’ll bite, keep going
1973 CB 750 K3
Online BenelliSEI
  • 1969 cb750
Re: Oh dear ...
« Reply #143 on: July 03, 2021, 05:59:23 AM »
Offline 69cb750
Re: Oh dear ...
« Reply #144 on: July 03, 2021, 08:19:52 AM »
The show must go on !
1970?
69 diecast.
Offline 69cb750
Re: Oh dear ...
« Reply #145 on: July 03, 2021, 08:21:30 AM »
Offline 69cb750
Re: Oh dear ...
« Reply #146 on: July 03, 2021, 08:22:18 AM »
Online BenelliSEI
  • 1969 cb750
Re: Oh dear ...
« Reply #147 on: July 03, 2021, 11:39:02 AM »
What paint do you use?
Offline 69cb750
Re: Oh dear ...
« Reply #148 on: July 04, 2021, 04:23:38 AM »
Frame paint is Delfleet single stage + catalyst
Online BenelliSEI
  • 1969 cb750
Re: Oh dear ...
« Reply #149 on: July 04, 2021, 05:33:01 AM »
Nice results.
