Author Topic: M unit wiring  (Read 1688 times)
Offline Bastaldo
M unit wiring
« on: March 13, 2020, 02:49:10 PM »
I searched the forums and tons of great info but still a little confused.
Does the return wire from the R/R (the red one that charges the batter) go back into the m unit’s power supply (the bolt at the bottom right) or does it  bypass the m unit all together and get attached to the wire that goes straight to the batter (with a main fuse).
Also, can the ground wire go to the frame or does that need to be grounded somewhere specific.
Thanks!
Offline calj737
  • Moderator
  • I refuse...
Re: M unit wiring
« Reply #1 on: March 13, 2020, 02:53:33 PM »
My approach to it.
Offline Bastaldo
Re: M unit wiring
« Reply #2 on: March 13, 2020, 03:11:49 PM »
Your approach is to bypass the m-unit and splice the return wire into the power wire?
Offline Jnel
Re: M unit wiring
« Reply #3 on: April 07, 2020, 04:16:14 PM »
I did this up to help get me thru the Wiring process.   I needed something to keep me keep stuff organized a d i think this is easy to follow compared to some othets I've seen.
Good luck
Jnel
Sent from my SM-N950U using Tapatalk
Offline guamjake
Re: M unit wiring
« Reply #4 on: April 12, 2020, 12:08:00 PM »
What is the best way to "piggyback" the wiring, so say if I need a 1 amp fuse for my m lock and also a 1 amp fuse for my gauge and I want to just have both these coming from the same 1 amp fuse, do I take 2 wires coming out of that 1 amp fuse or do I split the 1 wire coming out of the 1 amp fuse somehow into 2 wires?
 Another example of this is from AUX you run 1 wire to both coils, what is the best way to run the wire then have it split?
Offline calj737
  • Moderator
  • I refuse...
Re: M unit wiring
« Reply #5 on: April 12, 2020, 02:54:27 PM »
You don’t want two devices that each draw 1 amp of protection behind the same fuse. That defeats the purpose.
Run a single wire to one coil, then run a jumper to the other coil.
Offline guamjake
Re: M unit wiring
« Reply #6 on: April 13, 2020, 07:06:55 AM »
Thanks, calj
I somewhat figured the first example wasn't the best.
I guess the meat of my question is what is the best way to "jumper" these wires? What type of connector?
I found the Tifco 44294 connector seems to be a good option and they make it for several different gauges of wire, what would you recommend?
Offline calj737
  • Moderator
  • I refuse...
Re: M unit wiring
« Reply #7 on: April 13, 2020, 07:58:48 AM »
Not my preference. I use simple Molex-type self locking connectors. For powering 2 devices from a single run, get a 2-way. From source to one pin, jumper to other side of the same connector. On the mating connector, run 1 separate line to each of the 2 locations.
For the coil jumper, I use a ring terminal and wind the jumper lead to the end of the wire for crimping inside the ring terminal. You only need 18AWG wire here, so you can use a 16AWG ring for the doubled wire, a proper 18 for the jumpered lead to the opposite coil.
« Last Edit: April 13, 2020, 08:00:27 AM by calj737 »
