Author Topic: An ultimate trailer?  (Read 3695 times)
Offline kerryb
  • Not a very
« on: March 14, 2020, 03:54:01 PM »
I'm thinking of building a bike trailer to bring my bike back to Florida from Buffalo next winter.  If I'm going to have a dedicated bike trailer, it should also support camping when the bike isn't in it.  That way it could allow me to go "bike" camping in october when Buffalo weather precludes riding the last 500 miles home due to nasty rain, cold, snow.
Sure, I could buy one for the task, but I want aerodynamics (like a teardrop trailer) as well as secure parking/portable garage function.  Building it myself would allow composite construction and lighter weight materials to make it easier (gas efficient) to pull.
Your opinions/ thoughts are welcome here.
p.s.  I have a landscape trailer to go fetch project bikes, but it is not suitable for a nice bike on snow and salt covered roads.
Re: An ultimate trailer?
« Reply #1 on: March 15, 2020, 08:29:40 PM »
 I've been planning a someday trailer, like the one I built for our Jr Dragsters. The bed tilted at the front of the axle so I could leave it hooked at the hitch and roll off. I was weary from picking up little race cars. The tilt was controlled by a  tongue jack. I used 1/8" thick x 1 1/2" square tube, maybe should have been bigger angle iron for less fitting/welding. I used new commercial grade Extension cords for the wiring and ran it through the frame.
 I'm thinking of using 40 chevy rear fenders on the new one with dexter torsion axles or Timbren stub axles, no cross bar with those so it can be low. Curved angle iron on the sides could be filled in with flat composite sheets to weather proof it, or even a V nose like the newer enclosed bike trailers.
« Last Edit: March 15, 2020, 08:31:44 PM by Don R »
« Reply #2 on: March 15, 2020, 08:39:48 PM »
We should all get together and throw our ideas on the table, those of us who want to.
 My idea uses stub axles on off set mounts that go down to say 7 inches off the ground then tilt the trailer rails or use a low ramp, pushing up 7 niches is not so hard.
 Centerline spindle mount 15 inch wheels with car or bike rubber.. probably flat profile is desired.
 Will do a little sketch soon.  I have Centerlines, 4.0 wide I think
Offline bear
  • Leeton in Australia
« Reply #3 on: March 22, 2020, 03:10:19 AM »
Even 7 inches is a struggle for me these days Frank.
But I desperately need a trailer, so we plane to build the chassis in three sections.
It will pivot at the tailgate and in front of the stub axles. (I hope) ::)
The whole floor will be at ground level, with the tow hitch still attached.
I hope to use the Timbren units as well Don.
Brian
« Last Edit: March 22, 2020, 03:15:06 AM by bear »
Offline jgger
« Reply #4 on: March 22, 2020, 12:48:50 PM »
How about mounting the suspension on some kind of a cam so the whole trailer can " kneel" for loading?   Block the wheels to raise/rotate the suspension back to road ready by backing g up, and lock back into place with a pin.
« Reply #5 on: March 22, 2020, 09:21:47 PM »
I think MCRider (Ron) had a trailer that allowed the deck to be lowered for loading??
« Last Edit: March 22, 2020, 10:07:22 PM by scottly »
« Reply #6 on: March 23, 2020, 01:57:16 AM »
 I saw pics of a rat rod towing a rat trailer with a rat bike on it. The thing was awesome, I should have grabbed a screenshot or something.  I believe it was air bagged.
« Reply #7 on: March 23, 2020, 02:20:15 AM »
Tow Smart Trailers has a nice ride on design, bought the three rail version in November when they were doing a redesign. It was ready in late Jan but I wasn’t ready to go get it and I let them sell it to someone else and am in line for the late April. Wish I had gotten it in Jan now that the virus is locking down everything...
It isn’t super low but is able to be safely ridden on so it doesn’t require help loading. Ideal when you live alone.
The three place will never be a three bike due to weight and space...that is fine. The bike gear can be pulled and it is a utility trailer...
David
« Reply #8 on: March 23, 2020, 01:07:38 PM »
Good memory Scott!  Yes, Ron has a Rampfree....
http://www.rampfree-indiana.com/home.html
https://www.trailersauce.com/trailer-plans/ground-loading-trailer/introduction/
Offline jgger
« Reply #9 on: March 24, 2020, 05:41:53 AM »
Pretty much what I had in mind, I had not seen one before. It looks easy enough to build.
« Reply #10 on: March 24, 2020, 08:08:53 AM »
 My old '62 front engine dragster trailer had to be unhooked at the hitch end to load and I always worried about pushing it into the tow car. I built the next one to stay connected. It tilted on a pipe just ahead of the axle, but it was long and didn't have much slope.
  It also had a fixed dolly wheel so the tongue jack would lower it to the wheel for parking by hand.
Offline kerryb
  • Not a very
« Reply #11 on: March 24, 2020, 04:53:08 PM »
That, is a very inviting idea.  The scariest thing I do is put bikes up on the trailer or lift ( I ride the goldwing onto the lift table!).  Now the question to answer is buy or build.  I think there is room for a teardrop shaped cover on that design.
 Thanks guys.
« Reply #12 on: March 24, 2020, 10:23:50 PM »
 I looked up trailer stuff and now there's an e trailer ad at the top of the page here! It has timberens on it. I want the ones with brake flanges, not a refit type but axle-less one. My old 40 coupe doesn't stop great even though it has disc/drums from 1974 so I use trailer brakes on anything behind it.
Offline bear
« Reply #13 on: March 25, 2020, 12:17:48 AM »
Thanks for the links Stevo
« Reply #14 on: March 25, 2020, 08:35:15 PM »
 I love the trailersauce blueprint. I will have a car body jig left over and it's mostly larger tube but the conversion to a few larger pieces shouldn't be an issue some day.
 Thanks Stev-o and kerryb. I've posted on this in the past but this one got some awesome ideas.
« Reply #15 on: March 26, 2020, 01:12:28 PM »
i built a 7x4 box trailer a few years ago and used trailer sauce for my inspiration,i made a bike holder that bolts in for it,both front and rear tailgates hinge and slip off,its a bloody great site,also built a 3 bike trailer which i sold.
« Reply #16 on: March 28, 2020, 09:27:00 AM »
 My brother has a farm store trailer that I made two tire chocks for, the right one may be moved to the middle for one or two bike hauling. He likes outdoor plywood over the mesh bed but it sits outside in the shade and it gets slimy. I have loaded two 750's facing front and a cl100 facing the rear.
 I've used my truck ramps to load across and over the trailer and into the truck bed too. It's not too hairy if you tie the ramps down.  Makes a loooong ramp with a shallow angle.
Offline Kelly E
  • Geriatric Hooligan
« Reply #17 on: March 28, 2020, 09:09:40 PM »
I made a 12'x7' flatbed trailer from a free travel trailer frame with a 4500lb drop axle with electric brakes. It is totally silent even bouncing over the railroad tracks, I hate noisy trailers. I beefed it up, built railings and a winch mount, installed all new lights and built a new wiring harness and decked it in two overlapped layers of 3/4" T&G underlayment covered in bedliner. I can haul two big sport touring bikes no problem as well as my MG.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #18 on: March 28, 2020, 09:27:58 PM »
Nice MG and trailer
« Reply #19 on: March 28, 2020, 09:37:21 PM »
It's a GT. A guy from school race one in get hillclimb here, V8 powered.,
« Last Edit: March 28, 2020, 09:39:18 PM by 754 »
« Reply #20 on: March 28, 2020, 10:22:27 PM »
The Rover V-8 was a descendant of the aluminum Buick 215 from the early '60s. Cool little motors, but not much in the way of performance parts available at the time.
Offline Kelly E
« Reply #21 on: March 29, 2020, 08:23:44 PM »
1983 Honda CB 1100F
Offline Bankerdanny
  • Endeavor to persevere
« Reply #22 on: March 31, 2020, 02:33:50 PM »
That looks familiar
« Reply #23 on: April 01, 2020, 10:13:01 AM »
 My 69 firebird body jig, when it's raw material again, it will be my new bike trailer. I want wheel fairings ( fenders on both sides of the tires.)
https://photos.app.goo.gl/6PrEpDw2tT42MKnC6
Offline Kelly E
« Reply #24 on: April 02, 2020, 08:04:20 AM »
A better way to go is the GM 60 degree V6 2.8/3.1/3.4 motor. they weigh within 20 pounds of the stock motor and a 3.4 is 180hp. The 2.8 that I built for my 85' GMC S-15 is around 240hp, stock it was 110hp. It is a lot of fun to drive with the suspension mods. It is very hard resisting installing that motor in my MG but I am building a 10 to 1 compression with a lightened and balanced rotating assembly MG motor for it.
1983 Honda CB 1100F
