Author Topic: cb750 camshaft end bolt torque?  (Read 345 times)
Offline macvit7906
« on: March 14, 2020, 07:20:03 PM »
Installing a new webcam.
Is there a special torque spec for the camshaft end bolt that holds the washer on the end?
Number 7 here: http://www.hondachopper.com/engine/fiche_pages/F0/F0-Camshaft_Towers.pdf
Or just follow the 8mm torque spec of 14.5 ft-lbs? use some red loctite?
Re: cb750 camshaft end bolt torque?
« Reply #1 on: March 15, 2020, 08:48:50 AM »
 Be careful holding the cam....don't snap a flange off (I have seen it done) ::) Blue loctite is fine Matt....just clean the bolt and hole with brake cleaner before assembly.
Offline macvit7906
« Reply #2 on: March 15, 2020, 09:08:24 AM »
Thanks Mike! Will be careful and go to 14 ft-lbs with blue loctite
