Author Topic: Tank painted & cleared - now what?  (Read 935 times)
Offline Hutch
  • 1982 CB650SC
« on: March 17, 2020, 11:07:25 PM »
Need some paint finishing advise from the experts out there.  I painted and cleared my tank using Aero 2K color and 2K clear.  I'm left with a slight orange peel that I plan to wet sand out with 2000 grit paper.  Ultimately, I want to end up with a very low gloss finish without swirl marks or scratches from sanding.  What compounds and pads do you recommend, and in what sequence?  I have a variable speed buffer that goes from the 600 RPM to 3350 RPM range.
« Last Edit: March 17, 2020, 11:10:12 PM by Hutch »
Offline calj737
  • I refuse...
Re: Tank painted & cleared - now what?
« Reply #1 on: March 18, 2020, 05:33:12 AM »
Wet sand with 1200 in one direction, then 2000 in the opposite, then up to 3000, then switch to a scratch compound on a firm pad (I use white), then to a polishing pad with a softer compound for finish (I use red pads here).
Offline Hutch
  • 1982 CB650SC
« Reply #2 on: March 19, 2020, 12:44:15 AM »
Thanks for all the detailed info calj737.
Offline bear
  • Leeton in Australia
« Reply #3 on: March 19, 2020, 03:26:13 PM »
What carj said. ;D
After final cutting buff, a good clean with soapy water followed by a polish with a clean buff using corn flower.
This will remove any swirling and heat marks. Adds a nice deep luster as well.
Brian
