I have used similar lower priced. Make sure the fitment before tighten the valve cover.
If checking this, OK.
If hole for bolt does not line up, gasket can be ripped when tighten or removed.
Especially the curved area cyl 2,3 exhaust side. Gasket can collide with Cam holder and need to be dressed a little with a scissor, if not hole(s) will not line up with head, gasket will be damaged. A ripped part of that gasket can fall inside cam chain tunnel.
I know somehow, more than once
Strange fibers later found in the pan...
Honda is very good, can be reused several times when lifting cover and back again as Hondas other gaskets. (Light green)
Only time I have damaged them is with additional sealer that made it to stick to cover and broke when lifting cover.
