Author Topic: Twin Leaks!!!  (Read 935 times)
Offline SalNYC750
  • I’m a big fat Italian Guy so sue me!!!!
Twin Leaks!!!
« on: March 20, 2020, 01:54:45 PM »
or twin peaks!  8) 8) 8)
On center stand, after a 15min ride I put her up for a few day then this?
Where should I be looking for leaks?
im not the sharpest tool in the basket so big NYC thank youz guys to all who help this lunk!!!!
74&72cb750 in various states of disrepairs!
Offline Robbo
Re: Twin Leaks!!!
« Reply #1 on: March 20, 2020, 02:17:18 PM »
Directly above those two stains
1973 CB350 Four, 1975 CB550K
Offline jakec
Re: Twin Leaks!!!
« Reply #2 on: March 20, 2020, 02:22:33 PM »
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Re: Twin Leaks!!!
« Reply #3 on: March 20, 2020, 02:49:00 PM »
vertically above those two stains.
Offline SalNYC750
Re: Twin Leaks!!!
« Reply #4 on: March 20, 2020, 03:15:48 PM »
wise guys lol I know that- it’s running down the frame, but from where???
Re: Twin Leaks!!!
« Reply #5 on: March 20, 2020, 03:18:02 PM »
from within the motor.
Offline scunny
  • don't call me expert
Re: Twin Leaks!!!
« Reply #6 on: March 20, 2020, 03:20:27 PM »
clean it then dust the motor with talcum powder. this should show the origin of the leak.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline BenelliSEI
  • 1969 cb750
Re: Twin Leaks!!!
« Reply #7 on: March 20, 2020, 05:29:38 PM »
That’s not a leak. Just a bit of rust proofing........
Offline sixthwisconsin
  • With an 1855 Springfield, I'm a
Re: Twin Leaks!!!
« Reply #8 on: March 20, 2020, 05:40:26 PM »
these bikes sweat...
Mine from the shifter shaft which you seem to have as well. Not much, just a little and I'm sure a seal change would fix it. Yeah, not worth the trouble as its just a drop here and then.
Offline SF
  • I burn gas very well
Re: Twin Leaks!!!
« Reply #9 on: March 20, 2020, 05:43:48 PM »
Rustproofing.......spit beer outa my nose when I read that lol nice......it’s self preserving.
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
Online scottly
Re: Twin Leaks!!!
« Reply #10 on: March 20, 2020, 06:58:49 PM »
Carbs leaking out the over-flow tubes? Was the petcock left on?
Re: Twin Leaks!!!
« Reply #11 on: March 20, 2020, 11:08:21 PM »
CB750 up to K6?
Chain oiler is not closed leaking oil?
Offline SalNYC750
Re: Twin Leaks!!!
« Reply #12 on: March 21, 2020, 12:42:08 AM »
I’ll check later today thx fellas - so what’s the best degreaser for the aluminum engine????  8) 8) 8) 8)
Re: Twin Leaks!!!
« Reply #13 on: March 21, 2020, 12:54:12 AM »
Degreaser is written on bottles, right?
I use naphta that take grease, oil and tar (with brush) away, paint not harmed. 4L can to refill my 1L spray bottle.
Offline low-side
Re: Twin Leaks!!!
« Reply #14 on: March 21, 2020, 05:33:42 AM »
Careful with some brake cleaners.  Some won't hurt finishes, but I had Rural King's store brand take the original finish off a GL1000 front cover a couple months back.  As far as the origin of the leak, it looks like it is just dripping from the lowest points of either side of the bike so it could be coming from anywhere.  Like someone said earlier the way the stains are dark in the center and clear but wet at the outside make me think fuel leak, like a possible fuel leak out the carb drain tubes and then the fuel runs along the underside of the engine and picks up a little dirt along the way.
Offline SalNYC750
Re: Twin Leaks!!!
« Reply #15 on: March 26, 2020, 03:31:28 PM »
found where it’s coming from... ::)
drip drip down both side of the frame, identical spots from the engine.
time to pull or keep riding???? :-[
pick from shifter side looking up...
Offline ckahleer
Re: Twin Leaks!!!
« Reply #16 on: March 26, 2020, 08:50:33 PM »
The good news is it looks like the leak is above the head gasket. Maybe valve cover or head cover gasket.
Re: Twin Leaks!!!
« Reply #17 on: March 27, 2020, 10:09:04 AM »
Or breather cover in top of valve cover if not tightened or bad o- ring if any.
Re: Twin Leaks!!!
« Reply #18 on: March 27, 2020, 10:22:53 AM »
Would help to know what bike to make decent guess
Offline SalNYC750
Re: Twin Leaks!!!
« Reply #19 on: March 28, 2020, 03:23:26 AM »
K2 750/4
Re: Twin Leaks!!!
« Reply #20 on: March 28, 2020, 04:01:25 AM »
Tacho seal and/or pucks under cam tower
Re: Twin Leaks!!!
« Reply #21 on: March 28, 2020, 09:06:14 AM »
As a 32 year plumber and 52 year hobby mechanic I can say with authority always look above the apparent leak.
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
Re: Twin Leaks!!!
« Reply #22 on: March 28, 2020, 09:43:51 AM »
Would that have something to do with gravity Don?
Re: Twin Leaks!!!
« Reply #23 on: March 28, 2020, 10:06:16 AM »
I thought gravity was for apples, or is that custard!
