Author Topic: CB650z footpeg holder plate things  (Read 541 times)
Offline Eduard
« on: March 21, 2020, 11:26:31 AM »
Since im the only one riding this thing i dont need the back footpegs.
Is there some replacement for those big plates left and right that hold the footpegs and brake, gearchange etc?
They seem heavy and not particularly useful. (right side somewhat more useful than left because the brake pedal is so far back).
attached pics not my bike, but similarly modded, and hasnt come up with a solution it looks.
Offline Nicklopic
  • New York
Re: CB650z footpeg holder plate things
« Reply #1 on: March 21, 2020, 02:49:47 PM »
The 82 nighthawk had an aluminum like side mount that tool the place of those. I don't know if they swap over and I've seen them on a few 650s. Partszilla calls the step holders or something like that
The other option is to cut those off and do rearset if you like that look
80' CB650
Build Thread
Offline scunny
  • don't call me expert
« Reply #2 on: March 21, 2020, 05:06:31 PM »
Don't forget those plates on the Z mount on the swingarm pivot bolt and engine mount. you will have to make spacers up to replace or shorten and rethread  those 2 bolts.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline kerryb
  • Not a very
« Reply #3 on: March 21, 2020, 08:30:07 PM »
I made spacers (see pic), but it looks like your footpegs are mounted to those plates while mine (82 650sc)  are mounted to the engine mount bolt.
Is your brake pedal mounted to that plate also?
Take a look at raask rearsets for a cb750 k7 for an idea. They use a curved plate that attaches to the swingarm and engine bolt.
You might also consider a cable to operate the brake instead of a rod & pivot arrangement.  I think I've seen the cable operated rear brake system as a kit.  May have been for a sportster. Edit: see dime city cycles conversion kit.
Maybe the shorter plates from an '82sc could be retrofitted ( made shorter) to hold the rider footpegs where you want them.  That plate is somewhat hollow, so a 1/2" aluminum plate shaped like a raask plate might be easier
« Last Edit: March 21, 2020, 08:36:32 PM by kerryb »
Offline Eduard
« Reply #4 on: March 22, 2020, 06:00:59 AM »
Thanks for the replies guys, you're giving me some directions to look into.
i'll update this when i'll think of something genius...
« Reply #5 on: March 22, 2020, 06:04:13 AM »
Are you on the UK  site, if not why not? ( saw the escort in background!)
Offline robvangulik
  • Honda Fourever
« Reply #6 on: March 22, 2020, 09:06:57 AM »
That's not HIS pic, he's as Dutch as I ;D and should try www.cbfourclub.NL
Offline Eduard
« Reply #7 on: March 22, 2020, 10:42:50 AM »
Yeah no like i said its not mine. Its just some pics i had where you can see the plates well because of the contrast in colour with the swingarm. Mine are both black. bit harder to see.
But i do like that bike: And yeah he's English
