Author Topic: 76 550 fuel valve gasket/o ring  (Read 393 times)
Offline marko59
« on: March 21, 2020, 03:53:33 PM »
There’s a large o ring between the valve threads and the tank threads. Where can I get it, or what size is it. ( this is the valve with two outlets) thanks
Re: 76 550 fuel valve gasket/o ring
« Reply #1 on: March 22, 2020, 12:45:20 AM »
Is this the type held to the tank with 2 screw or screws onto a threaded boss?
Offline marko59
« Reply #2 on: March 22, 2020, 05:58:21 AM »
Threaded boss. I’ll try and get some approximate measures and shop around. Current one is pretty mashed.
« Reply #3 on: March 22, 2020, 06:00:26 AM »
Its normaly only available with the strainer"kit" from Honda and is more like a rubber washer than O ring
Offline marko59
« Reply #4 on: March 22, 2020, 07:11:50 AM »
Cool. I’ll look for that. Thanks.
Offline Deltarider
« Reply #5 on: March 22, 2020, 07:47:03 AM »
Although you will not find it listed separately at CMS or DS, it can be ordered from Honda as the same seal is used in a variety of Honda products. The pn is: 16997-467-000. It wil cost 3-4 bucks. Dimensions are: 11.8X3.55 mm. Forget about Amazon, Walmart and all the other slave factories that are making a killing right now. These are the times to support a Honda (marine) dealer.
CB500K2-ED Excel black
