Thanks for the help y'all!
The weirdest thing was happening with the bike. Turned out the left turn signal had blown out and so had the fuse for the main electrical line. It took me two more blown fuses on the drive home to realize that the bike died every time I went to turn left and had my signal on. The left turn signal wasn't blinking, even on my dash, but the headlight and 'neutral' light on my dash were blinking at the rate the turn signal normal blinks. Now that I yanked out the cables to the turn signal (I'm waiting to replace the whole signal because the socket also blew out), the left rear signal works with no problem and the headlight is no longer flashing.
If any of you knows why my turn signal would be blowing out my fuse and rerouting the blinking function to my headlight, I'm open to hearing about it. Otherwise, I'll probably leave it as is. The bike works fine now, minus a front left turn signal.
-Matt
