Author Topic: m unit install for dummies  (Read 5106 times)
Offline guamjake
« on: March 27, 2020, 06:31:12 AM »
Could someone please point me in the direction of an m unit install guide. I've got a limited history of wiring and electrical on cars and motorcycles but I need a starting point on what all I need to install a m-unit, lithium battery, signals etc. on my Cb750F 1978.
Thanks...
Offline guamjake
Re: m unit install for dummies
« Reply #1 on: March 27, 2020, 06:33:15 AM »
even just a wiring diagram with a legend on what all the abbreviations are for would be a great start.
Offline guamjake
« Reply #2 on: March 27, 2020, 10:52:35 AM »
Gauge- Cognito Moto Gps speedo- https://cognitomoto.com/products/cognito-moto-gps-speedo-and-small-tach?variant=1332958017
switchgear- no idea ?
switch key- mo. lock from moto gadget
munit- mblue
full harness
I haven't purchased any of this yet- I am still trying to make a plan. any advice is welcome
Thanks.
Offline guamjake
Offline guamjake
« Reply #4 on: March 28, 2020, 05:27:58 AM »
What does G stand for ?
R/R stand for ?
M stand for ?
The box with the 2 circle and squiggly line above M stand for ? (guessing the starter)
between R/R and the battery is that a fuse?
Im sure this is all basic stuff but I am learning as I go.. Thanks.
Offline river
« Reply #5 on: March 29, 2020, 09:47:38 PM »
G is for generator/stator.
R/R is for regulator/rectifier.
M is starter motor.
The box above M is the starter solenoid.
Look again...inline fuse is going to M-Lock.
Think this is the same schematic I used when wiring up mine. The only thing I can't recall is the inline fuse but I have a ton on my mind right now. I am using version 2, M-Lock, M-Blaze turn signals, one three Motogadget push button, one two button, and the Motoscope gauge. This was the first time I had done a full wiring job. It was a little daunting but not impossible and I love how it turned out.
Squirrel 1.0 http://forums.sohc4.net/index.php/topic,127186.2050.
ml
Squirrel 2.0
http://forums.sohc4.net/index.php/topic,176846.msg2055831.html#msg2055831
Squirrel 3.0
http://forums.sohc4.net/index.php/topic,185362.msg2146449.html#msg2146449
Offline ralt12
« Reply #6 on: March 30, 2020, 10:45:42 AM »
These are exquisite switches as well: https://messnermoto.com/product/motorcycle-switches/
This is a start for explaining the m-unit:
« Last Edit: March 30, 2020, 10:48:50 AM by ralt12 »
Offline Jnel
« Reply #8 on: April 07, 2020, 04:00:12 PM »
https://cognitomoto.com/products/m-switch-3-push-button-housing-7-8-black-black?_pos=9&_sid=c3efe72dd&_ss=r
bar switches I plan on using
I put this together to get my build finished up.  I drew this to fit my needs.  It may be a good start for you.
Regards,
Jnel
Sent from my SM-N950U using Tapatalk
Offline Jnel
« Reply #9 on: April 07, 2020, 04:04:01 PM »
In the drawing i use a ground bar.  I made this on up custom.   Worked great with Ferrell leads,  which by the way are freekin great!
Jnel
