Author Topic: advance spark  (Read 395 times)
Offline slaphead
advance spark
« on: March 27, 2020, 12:03:33 PM »
Hi all
Im having real trouble setting the timing on my CB750k 1977, everything seems to be 180deg out, I bought this bike as a box of bits so unsure on the advance spark is the correct one.
Anyone help?
Cheers Kev
Offline robvangulik
  • Honda Fourever
Re: advance spark
« Reply #1 on: March 27, 2020, 12:14:49 PM »
Possibly the cam is put the wrong way round on the advancer, pull it up and put it on again a half turn further. You'll have to pull the weights out a bit.
Offline slaphead
Re: advance spark
« Reply #2 on: March 27, 2020, 12:56:15 PM »
Thanks Rob will give it a try, i just watched hackaweek no:19 were he refers to the advance unit and it looks like mine is pre 73  ??? not sure if uk bikes are the same but that would explain the 180deg out.
Re: advance spark
« Reply #3 on: March 27, 2020, 01:08:17 PM »
There should be a mark on the end of the cam. The Hitachi unit like you have is interchangeable with the TEC units, not 180* out.
Re: advance spark
« Reply #4 on: March 27, 2020, 01:22:57 PM »
Cam is 180* wrong when engine runs with yellow and blue wire swapped where connected with main harness.
Offline fxef79
Re: advance spark
« Reply #5 on: March 29, 2020, 02:38:06 PM »
On the Hitachi advancer (which is what you have), the little "dimple" on the cam should be aligned with the Hitachi logo on the base plate (the "double circle").
Offline fxef79
Re: advance spark
« Reply #6 on: March 29, 2020, 02:39:07 PM »
And it is ONE of the multiple possible "correct" advancers... see here:
http://forums.sohc4.net/index.php/topic,178464.msg2071376.html#msg2071376
