Author Topic: Pesky oil pump shaft seal...  (Read 587 times)
Offline Sparco195
« on: April 01, 2020, 01:51:56 PM »
Rebuild the oil pump on my 1974 CB750 and I got to the point removing the small oil seal that is inside the pump housing. No matter that I've tried it's not coming out. I've actually ruined the housing trying.
I ordered and used pump off ebay and still have the seal to swap out but I don't want to destroy another one. Is there a special trick to get it out? Do people just leave it alone?
Offline Sparco195
Re: Pesky oil pump shaft seal...
« Reply #1 on: April 01, 2020, 01:53:28 PM »
It's only my opinion but it seems like it was put in backwards.
The seal lip is facing down towards the inside. I really don't see how to get it out...
Offline trigger
  • Engines built on reputation, not advertising.
« Reply #2 on: April 01, 2020, 11:15:34 PM »
Very easy once you know how >>> forums.sohc4.net/index.php/topic,175754.msg2045243.html#msg2045243
Offline BenelliSEI
  • 1969 cb750
« Reply #3 on: April 02, 2020, 05:28:49 AM »
Trigger........ Brilliant! One I’ll remember. Thanks.
Online HondaMan
« Reply #4 on: April 05, 2020, 07:32:25 PM »
Nice job, Trigger! That's simpler than my approach. Gotta go find a tap...
Offline tlbranth
« Reply #5 on: April 06, 2020, 10:29:24 AM »
Great idea
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline Keith
« Reply #6 on: April 07, 2020, 09:27:17 AM »
Yes, we used to use a tap to pull worn starter bushings on vw engines, etc. works great.
Offline fxef79
« Reply #7 on: April 07, 2020, 09:36:41 AM »
Based on that same concept... wouldn't an appropriately sized easy out work, too?  ("screw extractor")
Offline Keith
« Reply #8 on: April 07, 2020, 11:26:33 AM »
I think the flat bottom of the tap helps. The tap cuts a thread and pulls the piece upward as it turns. I don’t think the easyout would work as well.
