Author Topic: Does my 1981 CB650 have the origional tires?  (Read 632 times)
Offline ckahleer
« on: April 01, 2020, 03:37:34 PM »
Rear tire is a Dunlop K627, DOT code VA9115. Tread is low, almost gone.
Front tire is a Dunlop F11, DOT code NA3335. Tread at 50%
Bike has 10,800 miles and has not been ridden since 1993.
Offline ballinchestr
Re: Does my 1981 CB650 have the origional tires?
« Reply #1 on: April 01, 2020, 04:36:06 PM »
Hmm. I'm pretty sure my bike has the same tires and they're definitely not the originals. I could be wrong though.
Offline jlh3rd
« Reply #2 on: April 01, 2020, 04:47:49 PM »
there is usually a decal on the chain guard called a tire mark that has the names of the tires the bike was equipped with. The manual might also state this.
I know my 75 550F has this.
Offline scunny
  • don't call me expert
« Reply #3 on: April 01, 2020, 05:01:27 PM »
pretty sure they were Bridgestone as original.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline Flyin900
« Reply #4 on: April 01, 2020, 06:57:12 PM »
Probably not original tires with two different models on there and at least 12 years from production of the bike
Date codes don't correspond to any tire produced after the year 2000. There usually is a DOT in front of the number which you don't mention and would be on a 2000+ model year of tire too. The general thought is usually 5 years old unless there are extenuating reasons to keep them a little longer.
When in doubt change them out  ???
« Last Edit: April 01, 2020, 07:00:11 PM by Flyin900 »
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline Bankerdanny
  • Endeavor to persevere
« Reply #5 on: April 02, 2020, 08:27:42 AM »
I'm not sure why it matters. If the tires are from 1993 or before they should be replaced.
Offline ckahleer
« Reply #6 on: April 02, 2020, 09:23:38 AM »
[/quote]
I'm considering selling the bike. It is 100% stock, and was thinking original tires would be a plus.
Am I not correct on this?
« Reply #7 on: April 02, 2020, 12:30:28 PM »
[/quote]
Not unless the bike is going to a museum!
I would not recommend riding a bike with 39 year old tires.
Most buyers would rather have new tires than having to go through the time and expense of new tires and tubes.
Offline Bankerdanny
« Reply #8 on: April 02, 2020, 01:23:51 PM »
[/quote]
Original tires on a museum piece Sandcast would be cool and maybe add some value. I can't imagine it would make a difference on a 3rd year 650.
Offline Flyin900
« Reply #9 on: April 02, 2020, 07:56:09 PM »
[/quote]
THe original Flintstones from the factory in 1981 would be worn or date coded out after 12 years, so likely someone switched to Dunlop tires. Honda would not have put two different models of Dunlop tires in model K627's on the front and a Dunlop F11 on the rear. Possibly the owner needed to switch to those two Dunlop combinations, as the only combination that would fit the rims. Maybe it was a thing back in 1993, as a performance handling package. :) :o
Install new tires and if the new owner wants the old tires....... then here you go sir!
« Last Edit: April 02, 2020, 08:04:06 PM by Flyin900 »
Offline Kelly E
  • Geriatric Hooligan
« Reply #10 on: April 02, 2020, 08:50:08 PM »
I bought a 1980 CB 650 and it came with the same Dunlop's that you listed when it was new.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline ckahleer
« Reply #11 on: April 03, 2020, 08:03:59 PM »
I found the decal. It looks like they are the original tires.
Offline Kelly E
« Reply #12 on: April 04, 2020, 08:28:13 AM »
I can guarantee they are not the original set, more likely the second set. They only lasted me about 3k miles, most people 4k to 5k miles before they were bald.
1983 Honda CB 1100F
