Author Topic: Is the 75/76 CB750F rear hub offset?  (Read 700 times)
Offline david 750f
  • 1976 CB750F
« on: April 01, 2020, 03:57:50 PM »
I’m re-building the wheels with new DID rims and stainless spokes. I can’t find my disassembly notes 🤔.
Is the rear hub centered (centred) in the rim or does it have an offset?
It’s a 76 F with the rear disc.
1976 CB 750F
Re: Is the 75/76 CB750F rear hub offset?
« Reply #1 on: April 01, 2020, 04:42:08 PM »
They are usually centered.
 You could mount hub, sprocket, spacers ..then take a straight edge or 1 inch wide tape, hold against inside of spoke flanges, and see where that ends up on the front, check both sides it will tell you if it's centered.
Offline david 750f
  • 1976 CB750F
« Reply #2 on: April 02, 2020, 08:58:00 AM »
Found my disassembly notes!! The rear hub is centred for anyone checking this thread in the future😊
1976 CB 750F
