Author Topic: Front brake light switch missing  (Read 889 times)
Offline geosar
« on: April 02, 2020, 10:04:13 AM »
My 1972 Honda CB750 K2 with a K3 motor has had a lot of work done on it over the past decades.
The front brake hydraulic line goes straight to the caliper and the front brake switch wires are cut.  If I were to make this bike ADOT legal, how do I find the manifold which apparently interrupts the brake line and houses the pressure light switch.  I have been unable to locate this set up on line or in my Common Service manual.
Or secondarily, is there perhaps an aftermarket switch I might attach to the front brake lever to activate the rear brake light.  The pedal switch for the rear brake activated the light.
Or should I just forget about the whole thing.
Thank you in advance
George
Arizona
Re: Front brake light switch missing
« Reply #1 on: April 02, 2020, 10:07:03 AM »
They make banjo bolts with pressure switches built in.
« Reply #3 on: April 02, 2020, 11:11:39 AM »
You would also need to change to rwo flexi pipes with banjos
Offline Scott S
« Reply #4 on: April 02, 2020, 11:19:03 AM »
 There are also master cylinders with a brake switch.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline geosar
« Reply #5 on: April 02, 2020, 11:30:29 AM »
Thank you to all.
Apparently my "intense" research pretty much come up short.  I'm not surprised but I appreciate being directed properly.
Lots of experience here and I bow to your knowledge.
onward and now I must learn about banjo bolts and connectors.
Thank you again
George
Arizona
Offline geosar
« Reply #7 on: April 02, 2020, 12:59:07 PM »
My brake line plugs directly into the caliper-no banjo bolt.  Without getting too involved (this is obviously not an area I have explored), can I put the banjo bolt pressure switch directly into the banjo connector on the master brake cylinder?
Thank you
George
Arizona
« Reply #8 on: April 02, 2020, 01:04:58 PM »
Yes, you use the banjo bolt switch on the master. BTW, where in AZ are you?
Offline geosar
« Reply #9 on: April 02, 2020, 01:24:38 PM »
Just down the road in Prescott.  Thank you for the response.  This is my first SOHC project attempt.
Offline kerryb
  • Not a very
« Reply #10 on: April 02, 2020, 04:00:14 PM »
This 78 master cylinder has the brake switch in the housing, actuated by the handle.  A little press-fit switch hidden from view.
https://www.ebay.com/itm/1978-Honda-CB750-Four-H538-1-front-brake-master-cylinder-with-lever/233498235341?hash=item365d9451cd:g:ZzoAAOSwfEJeQU-k&redirect=mobile
Offline Scott S
« Reply #11 on: April 02, 2020, 04:26:31 PM »
 Look at the 3rd picture on this auction.  It shows the switch on the underside of the master.
https://www.ebay.com/itm/283514666491
'71 CB500 K0
'81 Yamaha XS650
Offline geosar
« Reply #12 on: April 03, 2020, 09:06:43 AM »
Thank you for the advise and help.
I feel the banjo bolt switch will be less invasive despite not being original.
George
« Reply #13 on: April 03, 2020, 09:52:34 AM »
Switching to braided stainless steel sleeved Teflon lines is a needed upgrade as your stock hoses deteriorate and start causing issues. It will firm up the brake lever and you will use banjo bolts attaching the lines.
