Author Topic: Anybody know what this is?  (Read 925 times)
Offline tlbranth
« on: April 02, 2020, 05:54:47 PM »
Just split the cases on my '70 CB750 K0. Took off the pan cover to sevice the oil pump and found this stuck to my magnetic drain plug. It's a thin steel disc with a small hole in the middle. It's shiny on one side and dull (from oil I'd guess) on the other. I have no idea whence it came.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline kerryb
  • Not a very
Re: Anybody know what this is?
« Reply #1 on: April 02, 2020, 07:18:06 PM »
Ooh, ooh, I know this one...its a washer!  A fender washer if you want to be picky.
Did I win a prize?
Offline tlbranth
« Reply #2 on: April 02, 2020, 08:19:20 PM »
It originated in the engine somewhere. I'm the original owner and I didn't put it there. I'm wondering if it's some sort of oil metering thing that belongs in a passageway somewhere. That's a metric ruler. The thing is only 8mm or so in diameter.
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
« Reply #3 on: April 02, 2020, 08:38:14 PM »
How big is the hole in the center? How thick is it?
Offline Old Moe Toe
« Reply #4 on: April 03, 2020, 01:54:52 AM »
No idea what it is but being the ORIGINAL owner of a KO is very impressive!. Well done old boy.
Offline Flyin900
« Reply #5 on: April 03, 2020, 03:04:05 AM »
If you check a KO parts fiche that looks like a washer that is inside the output shaft with a felt wad in front of it. There is a removerable nut with a thin shaft on it that covers the end of the output shaft.
That part seems to be on the very back part of the internal assembly, so look up the fiche for your bike to verify.
« Last Edit: April 03, 2020, 03:06:39 AM by Flyin900 »
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline tlbranth
« Reply #6 on: April 03, 2020, 10:36:54 AM »
OD is about 8mm. Hole is about 1mm. Thickness is about 0.75mm.
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline tlbranth
« Reply #7 on: April 03, 2020, 10:43:02 AM »
Good call Flyin. It does look like that part in the fiche. But darned if I can see how it wormed its way into the crankcase. There is felt in the hole but no washer! When I switched to x-ring chain a few years back, I plugged the chain oil hole with a piece of brass rod. Maybe something went awry there.
Thanks for spotting that.
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline Flyin900
« Reply #8 on: April 03, 2020, 11:41:49 AM »
Hey from one Naked Goldwing member to another brother no problem.  :)
« Reply #9 on: April 03, 2020, 11:56:14 AM »
I suspected end of chain over maybe , but it can't get thru shaft and into motor.
