Author Topic: Late vs early CB750 clutch cover  (Read 697 times)
Offline fxef79
« on: April 05, 2020, 08:26:26 PM »
Later clutch pack (K5 or K6 I think, and later?) is slightly longer by 2 or 3 mm.  I understand the later clutch cover, therefore is also slightly different in order to clear.
What's the easiest way to tell the difference?  I pulled the clutch cover on my engine, which is '72 cases, and I've confirmed has early clutch.  But I also have a clutch cover in a box of parts I got from the PO.  There are some definite differences, such as a more defined "lip" around the edge on the clutch cover on the engine, whereas on the "parts box" cover the bolt holes are slightly cut for the bolt head to seat down in a bit more, there's an extra flange near the kickstart shaft, and some of the ribs on the inside seem to be cut back a little.  I'm thinking I have one "early" and one "late" clutch cover.
Or am I making mountains out of molehills?
Here are some pics:
Re: Late vs early CB750 clutch cover
« Reply #1 on: April 05, 2020, 10:16:01 PM »
The late cover has a shorter, more flat nub on the inside where the boss that holds the outside chrome cover attaches, near the kick starter. You can use the late cover on an early clutch, but to use an early cover on a late clutch, the nub has to be ground down to prevent interference with the longer late basket.
Offline fxef79
« Reply #2 on: April 06, 2020, 04:43:04 AM »
Ahah!  Yes, I noticed that nub was rounded on one and flattened on the other. So I have one early and one late cover.  In my pics the one painted black is the one on the bike now and would appear to be the “early” type.
I also noticed the late type has just a bit more material in the casting around all the bolts.
Offline fxef79
« Reply #3 on: April 06, 2020, 04:43:51 AM »
