Author Topic: Yammy TT600  (Read 35103 times)
Re: Yammy TT600
« Reply #250 on: January 06, 2021, 10:42:34 PM »
i fitted new mitas e-07 front and rear,good on hi way not real good on serious dirt,havent lasted long either the rear is worn out after 4500 kays!im just gonna run cheap DOT knobbies from now on.
Re: Yammy TT600
« Reply #251 on: January 07, 2021, 03:06:59 PM »
Have not heard of those, cool tread pattern though.  I ordered Shinko's 244 Golden Boys, very cheap, both tires $100 shipped.  This bike will be off road 80%.
https://www.cyclegear.com/tires/shinko-244-dual-sport-tires?gclid=CjwKCAiA_9r_BRBZEiwAHZ_v12l9DuXLFzbYaPBjdSRvYmHgm37pT-_bT6g3xXoTM38yed0bvAC4_xoCY6wQAvD_BwE
Re: Yammy TT600
« Reply #252 on: January 09, 2021, 02:47:56 AM »
yeah it had these on it when i got it so got new ones after reading how long they lasted etc,#$%*ing hell its been all wheel spin off road,its a big engine for off road,they lasted #$%* all aswell and wernt cheap either,good on road is about all,i got given a used rear dunlop D606 road legal today,i chucked it on this arvo,just looking at it you can tell its gonna bite off road,hard to believe these are DOT?ill run this one out then replace both tyres,the hot ticket is to use a dunlop D606 rear and the pirelli MT21 front,both DOT knobbies and cheaper than the mitas,if they gonna be on hi way somewhat just run cheap dot knobbies,the dual purpose dont last any longer so far for me?
Re: Yammy TT600
« Reply #253 on: January 09, 2021, 02:55:43 AM »
just out of interest our local dirt bike store/warehouse can sell you a rear dunlop for 139 bucks,the local yamaha shop will supply and fit the the same tyre for 136 bucks if you take the wheel in!
Offline grcamna2
Re: Yammy TT600
« Reply #254 on: January 09, 2021, 10:50:02 AM »
Dave,that rear wheel in the bottom pic with the decent tire,what happened to your brake drum ?
75' CB400F/'bunch o' parts'
Re: Yammy TT600
« Reply #255 on: January 09, 2021, 03:32:39 PM »
it was already chipped when i got it.
Re: Yammy TT600
« Reply #256 on: January 13, 2021, 02:27:11 AM »
I bought a Yammy too Dave, a 1972 (or '73) RT360! It's got "dirt only" knobbies on it, brand new, but they're coming off, and I'm getting Heidenau Dual Sport K60 90/90-21 & 120/90-18 Tyres put on, on Friday so I can use it for both bitumen and dirt. Should be good. ;D
RT360 10 Jan 2021 by Terry Prendergast, on Flickr
Re: Yammy TT600
« Reply #257 on: January 13, 2021, 08:25:10 AM »
Looks a little small for you Uncle Terry!
Re: Yammy TT600
« Reply #258 on: January 13, 2021, 11:33:25 AM »
thatll be a heap of fun Terry,id put a side pull throttle on it and be wary of the autolube system,looks tough!
Re: Yammy TT600
« Reply #259 on: January 13, 2021, 03:38:45 PM »
Ha ha, yeah mate, but considering my penchant for self harm, I figure it'll be not as far to fall? ;D
Re: Yammy TT600
« Reply #260 on: January 13, 2021, 03:45:00 PM »
Thanks Dave, I haven't ruled out a full engine rebuild, it's had a "20 foot restoration" and I can see under the brush painted tank that there's probably enough bondo to fill the holes in the Titanic, and when I took the magneto cover off, water ran out. It'll take a little time, but providing I have the leg strength to start the fcuker, it should go like a rocket.
It looks like the autolube pump's been disconnected, even though the cable still turns it when you twist the throttle, and there's oil in the oil tank, but I think I'll just run 2 stroke fuel in it until I know what's going on. ;D
Offline grcamna2
Re: Yammy TT600
« Reply #261 on: January 13, 2021, 05:12:47 PM »
Terry,I prefer to use the Yamaha Autolube system for best lubrication together with Yamalube or equivalent 2 stroke injection oil.The pump can be checked on the bench to see if it has a good seal to keep the 2 stroke oil from seeping into the bottom-end:set it up by removing the pump and use the oil tank to see if gravity will cause it to leak while sitting for about a week.I would say replace the pump with an NOS one if you are going to keep it.
Re: Yammy TT600
« Reply #262 on: January 13, 2021, 07:08:19 PM »
Thanks Bill, yep you’re right mate, I should use the auto lube system and I will once I actually get the sucker going, but so as not to damage it before I can score a (preferably factory) service manual for it, I’ll Redneck it with premix. If you see a manual for sale, let me know? I missed out by minutes on a genuine factory manual overnight on Gumtree, the seller apologised for not taking the ad down after he sold it. ;D
Re: Yammy TT600
« Reply #263 on: January 14, 2021, 01:22:07 AM »
run pre mix!!@32:1,mate had one fail to lube and seized an engine,it was a good idea and worked when new but a lotta years have passed since then,look at all the YZs and ITs?all premix,i disconnected my DT400 one and ran premix.
Re: Yammy TT600
« Reply #264 on: January 14, 2021, 02:42:10 AM »
Ha ha, OK Dave, I'll initially run it on pre-mix, and see where it goes from there, if it goes at all........... ;D
Re: Yammy TT600
« Reply #265 on: January 14, 2021, 03:13:56 AM »
itll be a hoot on the road!in all seriousness they aint real good off road like any of those early jappers,the euro and spanish bikes in the day had the handling but maybe less reliable?,the yammy will have plenty of power and be reliable though once you fettle it Terry,fetch a good price in good nick,if that bike could talk?(it would most likely swear?)
heres my 74 dt400 with obligutory dented tank and ripped to bits seat cover!and heres my mate i bought it from with his #$%*ing near new TT600 the #$%*!!that was a few years later though,were still mates after all the years!hes into harleys now.
« Last Edit: January 15, 2021, 04:30:10 AM by dave500 »
Re: Yammy TT600
« Reply #266 on: January 14, 2021, 03:26:24 AM »
Beautiful Dave! I had 2 x DT250's, one in 1975(?) and another in 1980. Both fantastic bikes, and easy to start, unlike this thing. Probably too early to judge though, I'll give it a couple more days........... ;D
Re: Yammy TT600
« Reply #267 on: January 14, 2021, 03:30:15 AM »
yeah youll sort it,if got any compression and spark at the right time itll run,the transmissions were bullet proof etc,clutches got abused,no doubt ya got that for a song?
Re: Yammy TT600
« Reply #268 on: January 14, 2021, 03:48:57 AM »
Well I paid more for it than my FJR1300, VFR750, CB750F2, CB750K1, BMW K100RS, Yamaha XS650, Honda VTR1000F, Honda VTR1000R SP1, and a few others Dave, so it was a big song. Think "Born Free", or "Bridge over troubled waters", and that's the kind of "Song" I got it for. That's OK, I've always wanted one, so the money wasn't that important............ ;D
Re: Yammy TT600
« Reply #269 on: January 14, 2021, 04:05:54 AM »
i wish you lived next door,we could cut a gate in the fence and id have that smoker going by the morning!!
Re: Yammy TT600
« Reply #270 on: January 14, 2021, 04:26:19 PM »
I wish we did too Dave, I need someone with more leg strength than me to kick this fcuker over, it makes a CB750 look like a CL90 when my 100 Kg is trying to prod that starter into life! ;D
Offline grcamna2
Re: Yammy TT600
« Reply #271 on: January 14, 2021, 05:05:14 PM »
The ign timing is set with a dial indicator on that Yam. RT360 Terry ?
Re: Yammy TT600
« Reply #272 on: January 14, 2021, 09:52:37 PM »
lot of old points yammies are like that,say like 2.9mm before top dead centre or similar.
Offline grcamna2
Re: Yammy TT600
« Reply #273 on: January 14, 2021, 10:41:17 PM »
Dave,I've never set the timing on an RT360 but have on many other 2-strokes including the RD350's.I have the dial indicator/timing set.I can possibly send it to Terry so he can set his timing after he sets-up his points plate/condenser and de-oxidizes all the electrics under that cover.
Re: Yammy TT600
« Reply #274 on: January 15, 2021, 12:31:39 AM »
wow!im sure Terry would love that!!
