Author Topic: 76 CB400F dies under load  (Read 389 times)
Offline Gibbo
« on: April 06, 2020, 10:38:59 PM »
Diagnosis help please?
1976 CB400F - Engine stock, Airbox stock, Dyna-S ignition, Aftermarket headers and muffler
Carbs cleaned, tank lined, new filters and fluids, new ignition system upgraded.
Jetting unknown but the bike was previously running like clockwork before it sat for a decade.
+ At idle it will Rev cleanly to the red line if desired.
+ At rides smoothly with very, very light throttle.
+ A little more throttle and the engine starts to splutter.
+ Any more than quarter throttle it's like the kill switch has been turned off.
+ Roll the throttle back to just open and the engine rides smoothly again.
Riding with choke on kills the bike.
Riding with Airfilter removed makes no difference.
No vacuum leaks on intake
It's not the new Dyna-S ignition - the symptoms were the same with the 333 points and advancer
Give me some ideas please because I've reach the limit of my diagnostic abillity.
Offline Nurse Julie
Re: 76 CB400F dies under load
« Reply #1 on: April 07, 2020, 03:10:55 AM »
Check your air/fuel mixture screws. Also check your spark plugs, too back, running rich, too white running lean. Adjust by using the air/ fuel mixture screws.
Trust me I'm a Nurse, I promise it won't hurt....much
Offline minimo
  • 1977 CB550F 1975 CB400F 1959 Ducati 200 Americano
« Reply #2 on: April 07, 2020, 08:12:13 AM »
Thinking it might be possible after leaving your bike to sit for a while, some sticky varnish may have developed around your carb floats causing them to get stuck in a position, likely to starve your system of fuel, creating a lean mixture. Next time you experience any weirdness, give your bowls a good whack with a rubber mallet (or a wood stick against it) and see if that will loosen anything up. In either case, sounds like a carb clean weight be in order.
Have you checked your plugs after a shutdown? That might be telling of the condition.
« Reply #3 on: April 07, 2020, 08:18:53 AM »
Could be stuck rings damaged pistons have you checked compression
Offline robvangulik
  • Honda Fourever
« Reply #4 on: April 07, 2020, 02:28:19 PM »
Does the tank cap vent properly?
Offline Kevin
« Reply #5 on: April 07, 2020, 03:05:31 PM »
What others have said plus a crazy thought.....check the airbox for a mouse nest.
Sent from my SM-N960F using Tapatalk
A couple of 400F's and a
'98 Suzuki Intruder VS1400 ~ for long rides
Offline jakec
« Reply #6 on: April 07, 2020, 03:12:08 PM »
Every time I've had a 4 cylinder running  on 3 cylinders (350, 400, 500) it would die as soon as you put load on it
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
