Author Topic: cb750 headlight fuse  (Read 538 times)
Offline RonF
« on: April 08, 2020, 10:33:26 AM »
hi all,
I am in the process of finishing a full rebuild of my K4. The problem I have is that I cannot get the headlight to work and notice the fuse for the headlight does not get power on any switch setting.
Is this fuse dependant on the engine running?
Many thanks in advance for any help you can give.
Great forum, great help to someone new to the mark
Re: cb750 headlight fuse
« Reply #1 on: April 08, 2020, 12:32:14 PM »
Not that i have ever seen from Honda but could have been altered that way
Offline Bodi
« Reply #2 on: April 08, 2020, 03:48:43 PM »
It is not dependent on engine running. That was fairly common for 2-stroke bikes with magneto ignition but rare on 4-stroke machines.
Possibly your start switch is faulty. Headlight power passes through it, pressing to start turns the headlight off to reduce battery load while the starter is used. The fairly high current tends to damage those switches. The black/red wire to the HEAD fuse is connected to the main +12 switched power black wire in that starter switch, try connecting the black/red directly to a black wire for a test.
« Reply #3 on: April 08, 2020, 05:20:15 PM »
The 750 supplies power to that fuse via the START button when it is not pressed. These switches are often bad now. The START button, when unpressed, has a light spring contact that connects that switch's Black wire the Black/Red (some are Black/Yellow) wire from the handlebar, and that plugs into the one going to the fuse inside the headlight. Most of them change wire color in the harness, but a few still come to the fuseholder's plug on the same color it left the headlight.
Over time, the lightly-closed (unpressed) switch contacts burn, especially if the headlight was changed to a halogen type. So, the 'quick fix' is to unplug the supply wire to the fuse, up in the headlight, and plug it into a Black wire there. The headlight will always be ON, but at least you will have one!
There is another fix: you can use a relay in the headlight, connecting the Black to the fuseholder's wire via the NC contacts, and then connect the relay coil to the START button so it cuts out when you press START. I make a kit to do just that, if you're interested.
If you decide instead to get a new righthand switch, be sure to use a headlight of sealed-beam type, and not a halogen bulb. Otherwise you will be right back here in about 2 years or so.
Offline RonF
« Reply #4 on: April 18, 2020, 11:11:37 AM »
many thanks guys I will give those suggestions a go
