Author Topic: 76 CB750 tank decal question  (Read 633 times)
Offline redagain
« on: April 08, 2020, 02:35:26 PM »
Well with lots of quiet nights Ive finally decided to tackle the finish on my CB750 tank. I painted and cleared it last summer. Done a fair amount of tanks and decals..inserted a couple pics of vintage Kawi 2 stroke tanks I did this winter. My question that I haven't really been able to find via searches is the actual trick or true process to joining the corners..just haven't been able to find that specific advice on my searches. That's the only part that scares the hell out of me. I just got done painting the black insert and hope to be tackling it in a few days. Thanks in advance..Todd
75 cb750
83 gpz750
69 f4250 sidewinder
74 F7 175 enduro
78 DT175 enduro
78 SP370 enduro
Offline redagain
Re: 76 CB750 tank decal question
« Reply #1 on: April 12, 2020, 09:18:35 AM »
well no one seemed to have any technique or advice to share on joining rear end of tank pinstripes so I just used some logic and a good exacto and lots of water on the ends..guess I pulled it off..Im happy with it.
75 cb750
83 gpz750
69 f4250 sidewinder
74 F7 175 enduro
78 DT175 enduro
78 SP370 enduro
Online PeWe
« Reply #2 on: April 12, 2020, 11:20:58 AM »
I have not seen this thread. I should download photos of Yamiya's new tanks to see how they do it.
https://www.yamiya750.com/index.php?main_page=index&cPath=157_271_243
Offline redagain
« Reply #3 on: April 12, 2020, 12:45:15 PM »
I did not know yamiya was making tanks/side cover sets painted.  I seem to have better luck doing my decals dry than with water. I got the decals on leaving the backing remaining for about 3 inches on both ends then i used alot of water for joining stripe ends process, removed backing and the stop decal cover from bottom end of lightly spread it down with no pressure...did the same to top tail end letting it fall down over the top of bottom stripe end then lightly did all the step cutting with an exacto bringing each stripe to a point .. then trimmed off the tail end of bottom stripe end conforming to curve of the upper overlap..peeled off remaining which came off easy as no real pressure was applied...then squeegeed it down..done..all in all wasnt too bad..I imagine those guys at the honda factory really whipped em out. Wet sanded and polished it this morning and got my new badges on...i put about 5 coats of clear over them.
75 cb750
83 gpz750
69 f4250 sidewinder
74 F7 175 enduro
78 DT175 enduro
78 SP370 enduro
Online PeWe
« Reply #4 on: April 12, 2020, 11:50:10 PM »
The UK site has a description among other good tips and tricks
http://www.sohc.co.uk/index.php?topic=20183.msg179209.msg#179209
