Author Topic: Are all vinegars created the same?  (Read 1130 times)
Offline Ace Blackwell
  • 1977 CB550F - Resurrection in progress
« on: April 08, 2020, 06:12:26 PM »
All,
I bought white distilled vinegar a year or so ago to clean the rust our of my tank.   I used BBs and eventually small deck screws as recommended on here along with letting the take set full of vinegar for a few days.   With all I had read about vinegar eating a tank up and it will eat metal, I was surprised my tank didn't turn out any cleaner than it was. Granted it did look considerably better, just not at the results some have had on here.
I've been considering trying it again and became a little suspicious of my white distilled vinegar.  After searching the web, I discovered there are other vinegars like apple cider.
So my question is, which is the best vinegar for eating rust out of a tank?
Thanks
Ace
1977 CB550F Work in Progress
Offline Flyin900
Re: Are all vinegars created the same?
« Reply #1 on: April 08, 2020, 06:38:24 PM »
Just use the cheap white vinegar (gallon sizing) in a warm location for a few days. It may clean further or not inside the tank. I can't see it eating through a solid tank in a couple of days, yet personally I have never used it as a cleaning solution. The acetic acid level is around 6 % and that is what's doing the work.
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline dusterdude
« Reply #2 on: April 09, 2020, 04:22:31 AM »
I have used the works toilet bowl cleaner with very good results
Sent from my LM-X420 using Tapatalk
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline WhyNot2
  • I'm finally an
« Reply #3 on: April 09, 2020, 07:25:52 AM »
Watch out how long you leave stuff in vinegar.....
« Reply #4 on: April 09, 2020, 08:24:43 AM »
Nope, not at all. Look for pickling vinegar 10%.
Offline Pielz
« Reply #5 on: April 09, 2020, 09:07:50 AM »
I've seen folks use muriatic acid is as it only takes a few minutes. Definitely requires caution though. I used the POR15 kit and I believe that's what it comes with. Worked wonderfully and only took a few mins
« Last Edit: April 09, 2020, 09:13:21 AM by Pielz »
Offline brewsky
« Reply #6 on: April 09, 2020, 09:08:37 AM »
+1.....one week soak in "Heinz Cleaning Vinegar" (6% acidity)
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline CaptFatCat
« Reply #7 on: April 09, 2020, 12:22:22 PM »
I bet the acid in your vinegar ate the screws and bbs instead of eating the rust.
I used cheap white vinegar on a well rusted tank for 2 days without adding screws or bolts and it came out like a dream.
when you do need some abrasion to scrape the rust away a short length of steel chain works well and is much easier to get out.
Resurrecting a Herman Munster CB750 from a few old baskets of K2 and K7 parts.
Offline Greyhound
« Reply #8 on: April 09, 2020, 12:36:11 PM »
I’ve used both white and apple cider vinegar, and found that apple cider vinegar works a little faster at cleaning rust out of a tank. However, both work very well. Just give it time, a warm place and an occasional swoosh-around throughout the process.
I also leave the tank upside down for a few days to assure all the rust from the cap and topside of the tank get cleaned. Foamy packing sheet works well to seal the cap of gasket is brittle/leaky.
1977 CB550K3
« Reply #9 on: April 09, 2020, 02:56:26 PM »
i use vinegar for brass parts like jets,mollasses for ferrous stuff.
« Reply #10 on: April 09, 2020, 04:16:35 PM »
Hey thanks guys, I’ll give it another shot.  I’ve got a gallon and a half of white. I’ll start with that.
I appreciate the advice.
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #11 on: April 09, 2020, 04:20:25 PM »
Vinegar eats piston rings!
« Reply #12 on: April 09, 2020, 09:52:11 PM »
I used 12.5% vinegar as we have here. 5 days no problem. Make sure tank is filled completely.
Vinegar will cause rust if not filled.
Online spotty
« Reply #13 on: April 09, 2020, 11:40:50 PM »
On a related but irrelevant topic....
Chinese rice wine vinegar is great on chips ( fries for our colonial cousins )
Apple cider vinegar is great thrown in at the end of frying bacon onion and cabbage
Asian red or black vinegar is really good for pickling onions, gives an extra bite to an otherwise sublime delicacy
i blame Terry
« Reply #14 on: April 10, 2020, 12:26:21 AM »
Apple cider vinegar taste good to drink! Very healthy too.
1-2 table spoon, fill glass with cold water. It must be a tasty brand.
Offline Flyin900
« Reply #15 on: April 12, 2020, 04:24:52 AM »
I’m kind of partial to”Grey Pupon” vinegar myself, not too stuffy and cleans well. :o
