Author Topic: unidentified RC part  (Read 3212 times)
Offline corky
« on: April 09, 2020, 07:45:24 PM »
Hey guys,
Sorry if this isn't posted in the right area.  I have been going through some of my dad's old Honda parts, and found this plug.  I have seen a lot of RC Engineering parts, but I do not recognize this part.  Can someone help me identify it?  The plug part is around 1.25 inches
Thanks for the help!
Daniel
Re: unidentified RC part
« Reply #1 on: April 09, 2020, 07:58:17 PM »
That is a plug for the hole when the electric starter is removed.
Offline corky
« Reply #2 on: April 09, 2020, 08:01:44 PM »
Thank you!  I was trying to think of a place in the motor that would be plugged, and that did not cross my mind.  I didn't realize you could buy a plug from RC to do this.
Thanks again.
Daniel
« Reply #3 on: April 09, 2020, 08:10:52 PM »
I first used a rubber expansion plug, then made a custom plug that made the RC plug look like a fat pig. ;D
Offline corky
« Reply #4 on: April 09, 2020, 08:14:14 PM »
Yes, that plug you made looks really good!  And I bet it only weighs 1/3 of the RC plug, lol.
Offline low-side
« Reply #5 on: April 10, 2020, 09:48:42 AM »
I used a brass freeze plug on the last starter delete that I did.  Worked really well and I made sure that it didn't contact the area where the starter o-ring seals.
« Reply #6 on: April 10, 2020, 10:05:31 PM »
Pay attention here, this is why Scott has a 750 that only weighs 410 on the street..
« Reply #7 on: April 10, 2020, 10:32:56 PM »
Actually, it's now 404.5 pounds after the single Ducati brake rotor/twin piston caliper mod, with both the electric starter and the kick starter. After this weigh-in, I removed the now redundant 1.8 pound kick starter. ;D
Offline Johnny340
« Reply #8 on: April 10, 2020, 10:35:14 PM »
Awesome!
Sent from my SM-A705W using Tapatalk
1975 CB750F0 Super Sport
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Offline corky
« Reply #9 on: April 11, 2020, 06:32:01 AM »
That is amazing for a bike that weighed in at (500?) Originally? That is a cool way to weigh it as well.
« Reply #10 on: April 11, 2020, 07:16:47 AM »
Far more accurate than bathroom scales one end at a time!
« Reply #11 on: April 11, 2020, 10:56:31 AM »
More like 540 with gas..
 It hard to get even 40 lbs off a modern bike, because they use much lighter components,  the old 750,s were built like tanks. Real expensive to drop weight on modern bikes.
 Scott has a custom frame on that bike, every bit helps..  and good Morris wheels, they are lighter than the more popular Lesters.. better looking too...lean..
« Reply #12 on: April 11, 2020, 11:36:43 AM »
Scottly, isn't it an Enkei/Kawasaki wheel on the front?
« Reply #13 on: April 11, 2020, 12:29:29 PM »
 I have always been a fan of Morris wheels. Here us how you tell the difference, the hubs come off, a bearing plate on each side, and the spoke ends. What I dislike about them the rear 18 is too skinny, you have to go magnesium to get wider ones. The 16 looks better.
 MORRIS WAS USED AT FIRST by many OEM, s. HARLEY, Triumph I Think, Kawasaki, and the magnesium used by many factory teams. Then the bastards decided to copy them and use their design, Kawi had the most blatant  copy. YAMAHA  looks like they went after the Lester look.
  Harley to their credit, at least offered the Morris wheels as an accessory for many years.. on theirs the side plates were black, usually they are natural color.
« Last Edit: April 11, 2020, 12:31:50 PM by 754 »
Offline Tim2005
« Reply #14 on: April 11, 2020, 12:39:15 PM »
Scottly, great work. You obviously can't leave it at 403 lbs, what's the plan next to get it down to 400?
« Reply #15 on: April 11, 2020, 12:56:38 PM »
It's easy put kicker on, take starter out.,
« Last Edit: April 11, 2020, 01:58:34 PM by 754 »
« Reply #16 on: April 11, 2020, 01:17:47 PM »
BST rims and a carbon swingarm. That's what my brother did to his Ducati (he's crazy).
Offline Tim2005
« Reply #17 on: April 11, 2020, 02:08:13 PM »
I expect that's a very expensive hobby. Though you couldn't change out a Seeley swingarm, and BSTs would look too modern on a sohc. You can still buy new magnesium Campagnolos though...
« Reply #18 on: April 11, 2020, 02:38:57 PM »
You can get new Magnesium Morris style I think, but good wheels are 1000 each and upward from there for modern stuff. It's out of some of our economic universes.
« Reply #19 on: April 11, 2020, 04:46:59 PM »
 I know fellas....I'm just saying. Christ the BST swing arm was numbered around 50 I think and that is world wide. They haven't sold many of them. And they are not "plug and play".
« Reply #20 on: April 11, 2020, 05:34:56 PM »
 I know a few people can afford it, but it's easier to put that kind of money into a newer ride..
 A buddy works on high end V twin stuff, and guys are going to Ohlins forks , BST or equivilant wheels, trick monoblock brakes, and pretty soon they are up to 11 K to 13 K.. and to me that seems like a lot of money. .
 I guess that is only 8 or 9 K US... but none of our crowd are putting that into the front end of our SOHC bikes..
« Reply #21 on: April 11, 2020, 08:09:09 PM »
So just how expensive are the BST rims, not that I need a 6" wide rim. ;)
« Reply #22 on: April 11, 2020, 08:40:19 PM »
No, it's a Morris, but at one time I did have a Kawasaki wheel and forks on it. Need one or three? I have a front and rear from a 550, and a 2.5" rear from an unknown model..
« Reply #23 on: April 12, 2020, 02:07:35 AM »
is the rear 18" disc brake?
« Reply #24 on: April 12, 2020, 06:06:12 AM »
About 3,000.00 to 3,500.00 a set. They are nice equipment.
