Logo merchandise is available at the SOHC/4 Shop
If you are trying to power the electronic ignition, run a wire from IGN, Aux 1 or 2 to it. The Lock port is for the “keyed” ignition to send power to the mUnit. Basically, just like you have it is fine.
I always use revivals universal diagram and modify it for my builds. On this page they also have the AWG listed per slot which helps a lot as well.https://technicalarticles.revivalcycles.com/hc/en-us/articles/360009106131-m-Unit-Blue-Basic-Universal-Wiring-DiagramSent from my Pixel 4 XL using Tapatalk
Would the new wire from ignition out to rectifier be correct?
Quote from: Blakesblakey on April 11, 2020, 06:32:50 AMWould the new wire from ignition out to rectifier be correct?That should work, if you don't plan on using the 2nd Aux port I would power the reg/reg through that for easy of wiring. The original munit v2 only had 1 Aux output that's why a lot of the diagrams you'll see have them with multiple lines going into that port. Sent from my Pixel 4 XL using Tapatalk
Quote from: bomorr on April 11, 2020, 06:39:56 AMQuote from: Blakesblakey on April 11, 2020, 06:32:50 AMWould the new wire from ignition out to rectifier be correct?That should work, if you don't plan on using the 2nd Aux port I would power the reg/reg through that for easy of wiring. The original munit v2 only had 1 Aux output that's why a lot of the diagrams you'll see have them with multiple lines going into that port. Sent from my Pixel 4 XL using TapatalkOkay, if using the Aux 2 I would program it to be on with ignition? Thanks.
