Author Topic: 73 CB350F can't remove fork tube caps  (Read 768 times)
Offline Corkyk
« on: April 11, 2020, 06:46:09 AM »
Am trying to add fork oil and caps are unscrewed but they won't come out. they seem to be attached to the spring. Anyone ever have this problem?
Re: 73 CB350F can't remove fork tube caps
« Reply #1 on: April 11, 2020, 07:52:09 AM »
There is a rod threaded into the top nut and a locknut, the other end screws into the damper at the bottom
Offline Corkyk
« Reply #2 on: April 11, 2020, 11:42:38 AM »
Thanks  I  also put K&N style air cleaners got  tired of trying to get the stock one on back on. Do I need to rejet it if so what # should I use?
Thanks again
Corky
Offline Scott S
« Reply #3 on: April 11, 2020, 12:51:43 PM »
 These are two completely random, unrelated questions.
 Do a search for pods. There are a few posts on this on the first two pages alone.
 Yes, you will need to re-jet,  probably change the needle position and adjust your mixture screws.
 No, nobody can tell you what settings or jet sizes you need. Plug chips, dyno time and tuning will tell you.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Flyin900
« Reply #4 on: April 11, 2020, 01:48:01 PM »
Thanks again
Corky
You may need new rubbers for the air box that fit over the back of the carbs, since 45+ year old ones are never a walk in the park for even the most experienced rebuilder.  For $50 you can probably find an aftermarket air box rubber set which will be a lots easier than going the carb/jet route.
4 into 1 out of San Francisco is a good reseller who likely has the kit for sale.
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline Corkyk
« Reply #5 on: April 13, 2020, 07:24:09 AM »
thanks everyone for your input
