Author Topic: CB550 or CB500 Aluminum Side Cover Castings (build?)  (Read 19018 times)
Offline wolf550
Re: CB550 or CB500 Aluminum Side Cover Castings (build?)
« Reply #150 on: May 20, 2024, 12:46:36 PM »
if I get that far up into this with a business I would be investing in the metal 3d printers for this stuff and for fun get the mill equipment and go to town with as much stuff finned as I could handle. still have the starter delete plug in the works but where it is just the two ends that bolt into the engine and the starter cover itself
74' CB550 (Sold)
71' CB500/550 (Sold)
Offline wolf550
« Reply #151 on: May 20, 2024, 12:48:16 PM »
forgot to throw up a pic of how massive these sand moulds are. these are 13x15 and the bottom is 3 inches deep while the top is 6.
74' CB550 (Sold)
Offline wolf550
« Reply #152 on: May 20, 2024, 12:49:09 PM »
finally got through some of the fins but still far to go
74' CB550 (Sold)
Offline wolf550
« Reply #153 on: May 20, 2024, 12:50:07 PM »
it was easier to use the angle grinder with thinner cut off wheel and just eye it.
74' CB550 (Sold)
Offline wolf550
« Reply #154 on: May 20, 2024, 12:51:13 PM »
got the brazing rods on the way and went to pick up some propane and map gas from the local store for the front
74' CB550 (Sold)
Offline wolf550
« Reply #155 on: May 20, 2024, 12:52:26 PM »
the tabs fit really good now alot of grinding to get the back top away from the seat latch
74' CB550 (Sold)
Offline wolf550
« Reply #156 on: May 20, 2024, 12:54:00 PM »
after slotting the fins I went to work on the inside of each with 40 grit sanding disk. going to do a little more before hitting it with the rasp
74' CB550 (Sold)
Offline wolf550
« Reply #157 on: May 20, 2024, 12:55:27 PM »
pretty sure the rods can build up enough to get the lip filled in but if not removing it the cover would still look good
74' CB550 (Sold)
Offline grcamna2
« Reply #158 on: May 20, 2024, 03:24:08 PM »
That one's taking shape.
75' CB400F/'bunch o' parts'
Offline wolf550
« Reply #159 on: May 20, 2024, 05:56:21 PM »
thank grcamna2 if I was making more of these I would use the fins as a template to overlap the origina side cover so as to not have to remake but since this will be the end of the line I will let it go. I got 3 of the fins filed down mostly. after all of them are filed I can go back and finish them up depending on what gurp has in mind.
74' CB550 (Sold)
Offline wolf550
« Reply #160 on: May 20, 2024, 05:57:24 PM »
going to see if I can keep enough fin to round off the tips
74' CB550 (Sold)
Offline wolf550
« Reply #161 on: May 20, 2024, 05:58:11 PM »
im not sure about the bottom fin yet I will have to see how it looks with the rest of them completed
74' CB550 (Sold)
Offline wolf550
« Reply #162 on: May 23, 2024, 04:21:07 PM »
had some time before the storms came rolling in to work on the fins
74' CB550 (Sold)
Offline wolf550
« Reply #163 on: May 23, 2024, 04:22:11 PM »
once all of the scratches are taken out it should start to come together
74' CB550 (Sold)
Offline wolf550
« Reply #164 on: May 23, 2024, 04:23:55 PM »
I think that this cover would look good having some contrast either painted and the fin interior left bare or a two tone for it but I will leave that up to gurp for this one
74' CB550 (Sold)
Offline wolf550
« Reply #165 on: May 23, 2024, 04:24:54 PM »
still think it would look cool with the interior open
74' CB550 (Sold)
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #166 on: May 25, 2024, 05:35:54 PM »
It's coming out perfect. My plan is to run it completely bare just to show off the skill of its Creator. This 550 chopper has a few of your cast pieces and they really pop so well!
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Offline wolf550
« Reply #167 on: May 25, 2024, 08:38:22 PM »
Thanks gurp should be getting the rods next week and going to see about getting it finished up.
74' CB550 (Sold)
Offline wolf550
« Reply #168 on: May 26, 2024, 08:43:40 PM »
had a little time to work on the cover getting alot of the grooves and divets sanded out
74' CB550 (Sold)
Offline wolf550
« Reply #169 on: May 26, 2024, 08:44:56 PM »
once it get them out I can work on the inside
74' CB550 (Sold)
Offline wolf550
« Reply #170 on: May 26, 2024, 08:47:41 PM »
I was going to grind down that bottom fin but it works
74' CB550 (Sold)
Offline wolf550
« Reply #171 on: May 26, 2024, 08:50:50 PM »
Ill get those tabs drilled out to put some pins in them like the 750 side covers I did a while back
74' CB550 (Sold)
« Reply #172 on: May 27, 2024, 02:12:36 AM »
Wolf that is some nice work... Custom cover, worth far more than anyone would reasonably pay...
Nice custom build that is resto-mod or a custom build with reengineered and custom touches like these side covers.
Some nice paintwork and you have some custom bling no one else has making the bike very unique, not the of how cool is my cookie cutter copy of everyone else's build ideas turning out custom bike that don't look very different than any other cafe or whatever type bike.
Those will look great when finished up as they already look incredible. Very nice work.
Offline wolf550
« Reply #173 on: May 27, 2024, 07:10:50 AM »
thanks RAFster122s this has definitely come a long way from that first pic from the beer can days LOL! I can see when I am working on all of these pieces how a mill or a 3D printer or a CNC would give me the ability to mass produce everything but like everything I have made the little mistakes, deep grooves, thicker fins, casting pores I think it makes the pieces stand out and when I put the wolf550 on them Im glad that someone appreciated it enough to want it
74' CB550 (Sold)
Offline SF
  • I burn gas very well
« Reply #174 on: May 27, 2024, 07:29:42 AM »
Like listening to vinyl……
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
