Author Topic: Rick's rect/reg combo placement on CB550K  (Read 364 times)
Offline Erny
« on: April 13, 2020, 12:35:31 PM »
Those who installed Rick's R/R cmbo unit 10-100 (https://ricksmotorsportelectrics.com/OEM-Style-Honda-Rectifier-Regulator-10_100) on CB550K, can you share where did you place it?
if you have some photo, even better
Ideally I'd like to put in instead of OEM regulator or rectifier unit, but without need to modify in any mean the bike itself (no extra hole, nor modification of metallic "electric plate".
Why I want to replace stock OEM regulator - it is charging low in RPMs above 5500 (I tested two, result the same, after carefull cleaning, adjustment), electronic unit I tested (Electrex, UK) works good, stable, but too big to fit.
CB750K K7 USA model (1977)
CB550K1 USA model (1975)
Offline calj737
  • I refuse...
Re: Rick's rect/reg combo placement on CB550K
« Reply #1 on: April 13, 2020, 01:14:50 PM »
Install it on the back side of the electric panel thereby the connectors still route to the stock harness plugs. It will just fit between panel and battery box.
Offline Erny
« Reply #2 on: April 13, 2020, 01:52:00 PM »
Thanks!
