Good morning all. I have decided to pull the engine apart. I did another compression test this weekend. #1 has 35 lbs, #2 has 110 lbs, #3 has 110 lbs, #4 has 0. I put some oil in #1 & the compression came way up. Bad rings. That's the cylinder that had water in it. Don't understand whats going on with #4. Stuck valve maybe. I did a leak down test on it & I hear air blowing though the intake side. I'll know more when I pull the head off. The dual camshafts are a little intimidating to me though. To Steve O. I did get the service manual you told me to get. It's a Clymer manual & it's a big help. Thanks for the tip.
